telephone calling cards
Up until recently we had a long distance calling card that we used from home. We called into a local number then put the pin number in and then dialedthe number. The card was 1/2 cent per minute and except for a few glitchesnow and then the service was not bad. Every few months I'd call their tollfree number and add minutes to the card.The company just folded and I was wondering if anyone knew of another similar carrier that does this? There were also no fees or hidden charges either. We live in New Hampshire but thecompany was based in Massachusetts and had local numbers throughout New England. Thanks, Lenny
gregz
dialed the number. The card was 1/2 cent per minute and except for a few
glitches now and then the service was not bad. Every few months I'd call
their toll free number and add minutes to the card.The company just
New Hampshire but the company was based in Massachusetts and had local
You can usually find cards at convenience store, drug stores, groceries.
There ARe different companies. You have to look past the cell phone cards
which outnumber the regular cards.
Greg
c4urs11
live in New Hampshire but the company was based in Massachusetts and had
Did you try night shops and internet shops?
Cheers!
Allodoxaphobia
Cheers!
We bought our current LD calling card at Costco -- Verizon 700 minutes.
Jonesy
Geoffrey S. Mendelson
David said:
I have not personally tried doing dialup-modem connections over GV,
but I'd be somewhat surprised if you found it to work acceptably.
Long ago and far away, SKYPE worked with dialup connections. It had a special
codec that it used, and a better one for faster (ISDN and LAN) connections.
That was probably at least 10 years ago, I get "your computer is too slow"
messages with a 1.6gHz ATOM processor all the time, and occasionally
with a 3.6gHz dual core XEON.
I also get "you line is too slow" messages with a 50mbit down/ 3mbit up
aDSL line.
So although it was technically possible to do it at one time, it's not
likely now.
I think though we've missed the whole point of the question, he does not
want a VoIP solution as much as a callback system and I think Google Voice
does that. You go to their webpage and schedule a call, and their system
calls your registered phone line.
When you answer, it calls the number you requested and connects the two.
Of course, you need two phone lines, one to dial up with and one to receive
the call.
Geoff.
