Telephone line to Audio Interface
  • Thread starter Eduardo Fonseca Brasil
  • Start date
I need to build some hardware that will be connected to a regular
phone line and to the input and output of my sound card.
I want to be able to send sound from my computer to the phone line,
and from the phone line to my computer.
I've searched google, and found this site:
http://www.hut.fi/Misc/Electronics/circuits/teleinterface.html
It has lots of phone line interfaces, but i don't know which one i
should use. I don't even know if any of the interfaces from this site
will work.
Some of the interfaces only sends audio in one way (telephone line ->
computer), but i wanted one that could send the audio both ways.
Anyone ever done something like this?
Is this easy/possible to do?
Anyone could help me? (Maybe some other site, some successful
experience or some documentation)
Thanks in advance (and sorry about my bad english)
Eduardo
K
Karl Uppiano
Eduardo Fonseca Brasil said:
will work.
Eduardo
Your best bet might be to use a voice/modem
http://www.modemsite.com/56k/voice.asp. These modems are set up to interface
audio to phone lines. The work with your sound card to separate the send and
receive audio for you with minimal feedback. This would eliminate the need
for an external interface. You can just plug your phone line into your
computer.
Seth Koster
The absolute easiest way I can think of is to plug a microphone
into the mic input of your sound card and tape it to the earpiece of
the phone and to plug a speaker into the speaker output of your sound
card and tape that to the mouthpiece of your phone. This also
isolates the phone from the computer for safety.
My cordless phone has a jack to accept a handsfree headset, you
might be able to wire the sound card output and input to a cord which
plugs into the jack if there is one on your phone.
The question is what does the phone expect as input and what does
it send as output, and what does the sound card expect as an input and
send as an output. I don't know and without this info I'd be leery
of wiring my expensive computer to a phone. Maybe someone else here
has more knowledge of phones and computers and could help more.
I never even considered doing this, so I have no experience.
Eduardo
Your welcome and your english seems fine to me.
Dbowey
Eduardo posted:
will work.
You should use the one titled "Telecom hybrid circuits for other equipments
than telephones
Traditional transformer hybrid circuit"
Most telephone lines are not 600 Ohms, however, so you should use a 900 Ohm
resistor in series with about a 2 mFd capacitor as RB.
The 111C transformers (Repeat coils in Telco parlance) may be available on
eBay, but if not, any good (lots of iron) 1:1 transformer will do the job. You
need two identical transformers.
Don
Externet
Hello Eduardo.
The correct way to interface a telephone line is with ANY audio output
transformer. Those tiny ones canibalized from old transistor radios
work fine.
Connect the low impedance secondary ~8 Ohm IN SERIES TO ONE of the
telephone line conductors.
The primary will be a two-way audio path for any use, cannot be
detected, can be left permanently connected, and will not be damaged
with ring signals.
For protection and clipping, install 2 diodes in inverse parallel to
the transformer secondary. That will limit audio to 0.7V pp
Your english is better than many yankee's
Miguel
