terminating rubadue wire in flyback xfmr
Y
Yzordderrex
I am trying to design a flyback transformer. The feedback winding will
be 15v and there will also be a 5v winding as well. There will also be
a tertiary winding to supply 15v to the customer and to power a 12v fan
on the larger units.
European standards like VDE and IEC and CE and on and on and on tend to
complicate the designs so that I would like to use flying leads of
triple insulated wire for the customer winding. Is it possible to use
an insulation displacement type of a connector on the triple insulated
Rubadue or Furukawa TEX-E types of wire?
thanks,
Paul Mathews
Yes. The thin PTFE layers displace relatively easily.
Paul Mathews
Pooh Bear
No. IDC termination requires a PVC covering. Anything else will be
unreliable.
What size conductor btw ?
Graham
Pooh Bear
Paul Mathews
It's not PTFE. Using an unapproved cable with IDC is likely to lead to
long term problems.
Graham
Terry Given
Pooh said:
unreliable.
Graham
no. IDC requires suitable Cu OD and insulation thickness, thats all.
I've done it with Furukawa TEX-E, but only a few hundred thousand times
in a high-reliability industrial product :)
Cheers
Terry
Pooh Bear
Did you check with your connector vendor first though ? ;-)
IDC termination can be very touchy. One company I was with had a problem once
with unreliability that simply stemmed from using the flat cable when it
wasn't warm enough.
Graham
Terry Given
Pooh said:
oh yes. connectors are indeed tricky things.
wasn't warm enough.
Graham
Cheers
Terry
Paul Mathews
I assumed that you were referring to Rubadue or similar
'triple-insulated wire'. This wire has 3 layers of thin insulation
compounded from Teflon, Tefzel, or other material similar to PTFE. (I
have no idea why Graham insists on contradicting me.)
Here are 2 requirements for successfull IDC termination:
1) Insulation must displace or 'cold flow'
2) Contact spring-form must maintain pressure on wire so that
connection is 'gas tight'.
Obviously, requirement #2 implies that the wire and the contact be
'compatible', i.e., the contact must be engineered to fit the wire.
Owing to the bulk of the resulting termination, I've gone away from IDC
termination on my miniature transformer designs in favor of solder.
TIW strips easily using the appropriate heat settings on a thermal
stripper.
Paul Mathews
