Testing MOSFETs on my dead motherboard with a DMM
alpha_uma
On my dead motherboard's VRM circuitry, I have six MOSFETs with three of
each of the following types:
NEC K3296: These are probably equivalent to 2SK3296S (20V, 35A, N-channel).
JS214A (B550S03): Someone from another newsgroup said it might be equivalent
to 2SJ214A (60V, 105A, P-channel).
Would the standard routine of MOSFET testing with a digital multimeter (DMM)
(in the "diode" setting or as an ohmmeter)work while the MOSFET is still in
circuit on the motherboard (but motherboard not energized)? I'm referring to
the routine as described, for example, on the webpage
http://www.4qd.co.uk/serv/mostest.html
Also some webpages are saying that the DMM needs to supply 3.3V in order for
the MOSFET test to work. My DMM has a "diode" setting, but its manual says
the range is automatically set to 3V. Is 3V enough voltage to turn on a
MOSFET for this test to work? Is this test procedure independent of whether
the MOSFET is an n-channel or a p-channel device?
Any advice will be appreciated.
Al-U
Tim Perry
Al-U
use an oscilloscope with a 10X (10 megohm) probe.
follow standard test procedures.
first check power supply.
then start at one end of the signal chain and work forward or backward.
mosfets tend to be touchy about how they are treated when out of circuit
(see dire warnings about anti-static handling procedures on the replacement
parts package)
if it is a power transistor it MIGHT survive testing with an ohmmeter. the
MFR of certin high power industrial equipment which use banks of these (
@55$ ea) have recomended building a test jig. dont forget to add a bit of
heat sink compound when replacing the dead one(s).
alpha_uma
Unfortunately, I don't have access to an oscilloscope. I know, I know. I
probably should start investing in one.
parts package)
Yes, power supply is confirmed good. I tested it with a 12V system fan
connected directly to the PS, and confirmed it with my digital multimeter.
I'm still hoping and trying to determine if the MOSFETs are shot or not
while they are still in circuit. (Yes, I know. I need an oscilloscope to do
that, but I was hoping for some "miracle" advice from some troubleshooting
gurus here!)
Three 3300uF caps around the MOSFETs were bulged at their tops, so I removed
the suspect caps and replaced them with good ones having identical ratings.
The three suspect caps are confirmed BAD after removing them from circuit
(the resistance does not rise STEADILY to infinity in the standard testing
routine, it rises, drops and then rise again). I also replaced four other
3300uF caps near the CPU socket just in case. After testing these four caps
out of circuit, I found them to be still "good" (not like those earlier
three I mentioned).
But the motherboard still won't power up.
The problem is definitely on the motherboard. It just died on me one day. I
have subsequently bought another motherboard, and all other components
(including CPU, RAM and other peripherals) have been reused and are working
fine. It just that I want to find out what went wrong on this dead
motherboard.
Here is the test I'm performing and the symptoms:
Motherboard alone is placed on a wooden table top.
All peripherals removed. CPU removed. All RAM removed.
A 12V system fan is plugged into the system fan socket on the motherboard.
As a make-shift power switch, I modified a spare HDD LED jumper kit by
cutting the LED away and stripping the ends of the two wires still connected
to the jumper. This leaves me with a jumper with two separate wires coming
out of it. It is then plugged into the power switch header of the
motherboard.
The ATX power supply is then connected to the motherboard.
When I switched the power on (by shorting the two wires of my make-shift
switch), the power supply turned on for a very brief moment (probably no
more than 1 second) and then shut itself off. This is confirmed by the brief
operation of the system fan (which has red and green LEDs on the fan
assembly). It started to spin and the red and green lit up, but then it shut
down. My digital multimeter also said the power was briefly on (the voltage
readings on the 12V and 5V rails never got more than 1 volt). Using the
ON/OFF button on the ATX power supply itself, I reset the power supply. And
the test is repeated several times. Identical results every time.
It seems to me that there is a "short" somewhere on the motherboard, right?
I heard that when electrolytic caps go, they usually go "open", not "short".
A cap going "short" is rare, right? So, I'm just wondering whether I should
now start replacing the other still-not-so-tiny-for-my-soldering-iron caps
(three 1500uF caps, and six or seven 1000uF ones), or suspect and check on
the MOSFETs instead.
Yes, but I don't want to replace the MOSFETs yet unless I ran out of
troublshooting options.
Al-U
Tim Perry
Al-U
is this an older A-bit mobo? we got a lot of those in where half the caps
blew up.
turns out there was some issue with the electrolyte formula and a zillion
bad caps got installed and shipped all over the world.
alpha_uma
blew up.
No, it is an ECS P4VMM2. With regard to the "bad caps" fiasco, I have now
read many articles on it ever since my board went south a couple of months
ago, and I spotted the bulging caps on it. The death of my motherboard may
have something to do with those three caps with bulged tops, but I'm just
hoping that the problem did not get to the MOSFETs. It would be a lot
messier to replace the MOSFETs.
Al-U
me
motherboard. As a make-shift power switch, I modified a spare HDD LED
jumper kit by cutting the LED away and stripping the ends of the two
wires still connected to the jumper. This leaves me with a jumper with
two separate wires coming out of it. It is then plugged into the power
switch header of the motherboard.
make-shift switch), the power supply turned on for a very brief moment
(probably no more than 1 second) and then shut itself off. This is
confirmed by the brief operation of the system fan (which has red and
green LEDs on the fan assembly). It started to spin and the red and
green lit up, but then it shut down. My digital multimeter also said
the power was briefly on (the voltage readings on the 12V and 5V rails
never got more than 1 volt). Using the ON/OFF button on the ATX power
supply itself, I reset the power supply. And the test is repeated
right?
It sounds like you do not have enough of a load on the power supply.
Attach an old hard drive to it when you do the test. The mosfets are
likely ok. I have repaired a few boards with similar bad caps, they are
usually the only problem.
W
William R. Walsh
Hi!
That's a normal reaction from most ATX power supplies when the power is
first connected to them. You might double check to be sure the supply is
loaded enough (old drives are good for this purpose) and that you're going
about the right way of getting it to turn on.
You haven't come far enough yet to know if your board is good or bad. It
might be alright. I've fixed a few here with bad caps and all of them have
usually come out fine afterward, even if the bad caps exploded.
William
alpha_uma
William R. Walsh said:
Hi!
William
While it is true that most (if not all) newer ATX PSUs require an external
load in order to start properly, I have a couple of older ATX PSUs that are
exceptions. It is not an "insufficient load" problem for this particular ATX
PSU of mine that I'm using to test the dead motherboard. In fact, I like
using this ATX PSU as a piece of test equipment precisely because when its
green wire is shorted to "ground", it always turns on itself without fail
and with the correct voltage levels (as confirmed by my DMM)--with or
without any external load.
I've also tried loading the PSU with a spare CD-ROM drive and a floppy
drive. No difference. This socket 478 motherboard of mine has a short
somewhere. The MOSFETs are the most likely candidates at this point.
For comparison's sake, I have a spare socket 370 motherboad in known good
condition. When I connected the system fan ALONE to this motherboard--no
CPU, no RAM, nothing else exept the system fan--and then the same ATX PSU to
it, the system fan spins perfectly (with the fan LEDs flashing as usual) as
soon as I started the PSU.
(For a related thread that I posted at the sci.electronics.components
newsgroup, see
Al-U
