TFT LCD - a step backward ?
In the past, when the big-fat monitors were still been used, if
there's any problem with them, I can open them up and find and fix the
problem.
Nowadays, where the TFT LCD bunch is taking over, when a monitor fail,
it just dies. Can't be repaired, nada, zilch.
To me, the TFT LCD represents a step backwards. I have on my hand 5
TFT LCD monitors that lie belly up, and I just can't fix them ! All of
them have the same problem - the back-lighting fails, but since
everything is compressed into a compact module, there's no way to fix
it !
Darn ! !
Lionel
problem.
it !
I used to fix 3-4 dead LCD backlights a week. It's fiddly, but not all
that difficult.
problem.
it !
Oh yes you can fix them. Find a replacement backlight. Taking apart
the screen is a bit tricky (Ok sometimes a lot tricky), but it can be
done.
Pongo Potts
problem.
it !
Darn ! !
some repairer you are, can't fix a simple backlight.
James Sweet
problem.
it !
Darn ! !
Well it's not as if anyone gets the CRT monitors repaired anymore
anyway, everything is so cheap and disposable and I suspect it will
continue that way unless disposal costs rise significantly. Also many of
the most common faults with TFT monitors can be repaired, I usually see
dead power supplies or bad backlight inverters or tubes.
Lionel
Yep. All of which are cheap & easy to swap out. (Except for the tubes,
which require a fairly delicate touch.)
|>problem.
|>it !
|>Darn ! !
Unless they are like the 1989++ Sharp Plasma Screens, that were all
glued to hell, just popping out the "seems" would give you a good picture of
the situation..brownouts...cold solder/etc.... most are very *Tweaky*
After all the research, You only learn from your hands on
experiments.....
Meat Plow
problem.
it !
Darn ! !
I've replaced ccfls in a laptop display so I imagine it would be much
easier on a desktop display.
#1 Offishul Ruiner of Usenet, March 2007
#1 Usenet Asshole, March 2007
#1 Bartlo Pset, March 13-24 2007
Pierre Salinger Memorial Hook, Line & Sinker, June 2004
COOSN-266-06-25794
K
kony
problem.
it !
You must not be trying very hard. What would be interesting
is to see if there is some way to refit it with LEDs for
illumination. Not on a "good" monitor, just some junky old
thing as an experiment.
Lionel
They generally use the same LCD modules, so the job is almost
identical. The advantage of a desktop display is that you have a
little bit more room to work with when you're extracting the LCD
module in the first place.
Jim Yanik
That's what I expected, but I'm happy to report than I've had more
success fixing LCD monitors than I ever did with CRT monitors. The
most common problems are simple things like bad caps and back light
problems. The inverters can often be repaired (about half of them
just have a blown fuse). I've never had to replace a CCF tube in a
desk top monitor, but at least it's possible unlike when a CRT gets
dim. Most LCD monitors are also much easier to take apart and work on
than CRT monitors. There's no more rebuilding the deflection circuit
only to have everything blow up again because the unobtainable flyback
is bad. The best part is that LCDs are light weight and easy to
handle compared to CRTs.
Andy Cuffe
[email protected]
You certainly don't have colorimetry,geometry alignment and convergence
problems with LCD displays.
Andy Cuffe
problem.
it !
Darn ! !
Andy Cuffe
[email protected]
Sofie
usually the inverter board is NOT "compressed into a compact module"... and
many times can be repaired somewhat easily... backlights are not that
hard to replace in most designs but one has to be careful, gentle and not
"ham handed".
Dan
Meat Plow
Yeh it was the room to work in that I was talking about. I replaced the
inverter in my older Dell 15" and it was just an all around PITA.
COOSN-266-06-25794
Meat Plow
err ccfls and inverter.
COOSN-266-06-25794
jonpi
and also ... think of your eyes....
not every electron stops at the phosphorescent layer
you know, the electrons, from the gun(s), pointed at your head
mark krawczuk
hi, i tel ya know , tft monitors are no where as good as crt, crt have
better depth of color , thats why graphic designers still use em
James Sweet
It's about the same really, there's not much difference in the panels
themselves, the desktop displays just have a control board in there as well.
James Sweet
Huh? Electrons can't travel through the air, that's why even a tiny
amount of air leaked into a vacuum tube will cause it to stop functioning.
Meat Plow
Must have meant xrays.
COOSN-266-06-25794
