Sidecar Bob
- Dec 19, 2021
- 259
- Joined
- Dec 19, 2021
- Messages
- 259
I'm not sure if I should post this here or make it a project log. If it should be a log maybe a moderator can move it for me.
In 1972 I built a 4 channel stereo amplifier as my major lab project in electronics at college. The preamps are a design from the 1971 edition of the RCA Transistor, Thyristor & Diode Manual and the power amps are the "L'il Tiger" design published in the December 1967 Popular Electronics.
It has been stored for about 40 years for various reasons (for the last 22 mostly because it was in the attic and I just didn't think about it). Now that I'm getting involved in electronics again I decided to revisit it and see if I can get it working (no idea what I'll do with it if I do but I'll think of something).
When I built it I planned to use a simple transformer-bridge-capacitor power supply as recommended in the article but I couldn't get a 34V transformer as specified (for 4 amps I figure it would have had to be 5A) but I could get 40V 1A transformers so I decided to build separate power supplies for each amp. Naive 18 year old me thought I could just use a series dropping resistor but someone pointed out that if I did that the voltage at the current drawn by the amps would vary depending on how hard they were working at any given moment, which would change how much the resistors dropped and at low current it could be enough to kill the power transistors.
Being 1972 this meant using zener diodes to regulate the supplies so I moved things around inside the cabinet to make room for another heatsink and, after seeing how much heat they produced, added a big grill in the top.
Amazingly, I still have my notes plus the test reports for the power amps and preamps (I got a B overall) and was able to find them.
And even more amazingly, I was able to find the PE article and the RCA book online. I've attached the articles here. I'll post pics of the actual amp next time.
