threshold voltage of a MOS transistor
Emam
Jul 7, 2014
63
I have a basic question:
I would like to realize a switch (an interruptor) in a circuit, using a MOS transistor.
I need to change the state of the switch, with a very low voltage (for ex. 1 V, or even 0.5 V).
In other word:
if I have input signal =0 --> switch OFF
input signal =0.5 or 1 V --> switch ON.
Could you please tell me if this is possible.
Becuase I know that standard MOS are functionning with 3 V or 5 V as threshold.
Bests regards
Arouse1973
Adam
Dec 18, 2013
5,178
It will depend on how much current you want to control. Tell us more about your project and what you want to do.
Adam
Be aware that the threshold voltage is where the MOSFET just begins to pass any current, typically rated as the voltage at which 250uA will flow. The MOSFET cannot be considered ON at the threshold voltage (unless you only want 250uA or less).
I think what you want is a comparator that can switch at voltages close to 0 probably driving a MOSFET.
Emam
Jul 7, 2014
63
Thank you for your response.
In fact, the input of the switch is connected to a microcontroller (so I guess with low values of currents such as few mA).
All I want is that when the microcontroller sends a pulsel of 0.5 or 1 V amplitude ( duration few miliseconds), the switch turns ON.
And when the microcontroller sends nothing, the switch turns OFF.
The output of the switch is connected to a load resistance of 5 ohm.
Thank you in advance
So it is connected to an analog output on the microcontroller?
When you say "sends nothing" do you mean the output is at 0V?
What happens when the output is at 1.5V, 2.7V or are these not possible?
Do you have control over the programming on the microcontroller? If so, is there an extra pin you can use?
Emam
Jul 7, 2014
63
in fact the switch is connected to a programmable voltage DC generator which can gives values of 0.5 V, 1 V or other values by programming the microcontroller, this is the logic:
microcontroller ---> programmable DC generator --> switch
Yes by "send nothing" I mean 0V.
Its possible to have output such as 1.5V or 2.7V, we can have every value we want by programming the microcontroller.
I dont have any other pins of the microcontroller. I dont have any controls on it.
Arouse1973
Adam
Dec 18, 2013
5,178
So what value are you sending out? 0.5V, 1.5V, 2.7V or all of them. What do you want the circuit to do when it receives the voltage? What are trying to do?
Adam
Okay, so the DC output is the only signal you have access to, and it can vary between 0V and some limit you have not specified. You have only told us what you want to do on 3 of these voltages, 0V, 0.5V and 1.0V. What is supposed to happen on any other voltage?
And when you say 0.5V or 1.0V what do you really mean? It cannot mean exactly those voltages because it will always be off by some amount. If you really mean that you only want the switch on for those 2 voltages, you have to supply a tolerance, I.e how close to those voltages must it be to activate the switch. Is it activated at 0.49V or at 0.51V?
I expect that what you really mean is that it should be activated for any voltage above some lower limit, but that is not what you are saying.
Writing a specification is often more difficult than it seems.
We are not trying to be mean here. Engineers often (maybe always) get specifications that are not good enough to ensure we deliver what is wanted. Getting clarification is a major part of our job.
