Time Controlled Fader
Does anyone have any ideas on how to create a fader that can be time
controlled to say brighten at night and dim during the morning, using
a 150 watt incandescent lamp?
Baron
I thought that was what they use photo sensors for !
Jamie
Yes, a photo eye controlling a PWM circuit which drives the lamp
Any thing else or where you actually looking for some one to do
the work for you?
David Harmon
[/QUOTE]
How does a "photo eye" help you get to time control?
donald
David said:
On Sun, 03 Feb 2008 12:56:47 -0500 in sci.electronics.design, Jamie
How does the clock "know" when dawn is ??
donald
W
whit3rd
The easy way would be to connect an X-10 or similar module
in parallel with a dimmer switch for the 'dim ' setting.
Connect an appliance module in parallel so the thing turns full ON
when the timer/controller does the timed activation.
This means wiring the AC to two switches, and connecting
the outputs... but the X-10 timers and modules are easily
available.
Some of the X-10 modules can dim on command, but I don't
know if the timer/controllers have continuous-dimming-on-a-daily-
cycle functionality.
