Tips Lubricating Camera Tripod Heads?
K
KenO
Recently got a used MX350 Tripod. After using it for a while noticed significant sticking in certain areas,(especially when Pan vertically).
Did a forum search but only got. "Results for tripod head lubrication in sci.electronics.repair Search all groups Results: about 0 for tripod head lubrication No results found"
Hope someone may have had a similar problem and solved it.
Am interested in any tips taking apart a camera tripod head and lubricating it.
Ken
Cydrome Leader
Ken
I have no idea what a MX350 is, but try taking it apart and wiping the
parts clean. I tend to avoid lubing up stuff like this unless it came that
way. The junk and crud from rubbing parts is usually the problem.
Jeff Layman
Ken
Would graphite powder help? You can get it from locksmiths.
K
KenO
Hi Everyone,
"try taking it apart and wiping the parts clean"
Before posting, searched for a manual or least a parts list for the tripod head but found nothing.
I was able to find the parts list for the basic Manfrotto tripod head
http://mediacdn.shopatron.com/media/mfg/2747/media_document/live_2/804RC2_20060525.pdf?1272346475
http://www.ground-glass.net/diy/tripod-head-maintenance
Am sure the MX350 has much fewer parts.
Since it is only the vertical pan portion that is sticking would only like to take that portion apart and clean.
Did find general tripod cleaning info
How to Take Apart a Bogen 3047 Tripod Head
http://www.wikihow.com/Take-Apart-a-Bogen-3047-Tripod-Head
Unusual post "After you've figured out the simple disassembly process, goodluck trying to find the highly viscous and elastic lubricant they use...I'll give you ONE valuable hint. It's a field of interest that is highly dependent on ambient temperatures...."
http://www.howtofixcomputers.com/forums/digital-photo/overhaul-manfrotto-029-mk1-head-289825-2.html
Hope there are some general tips on taking apart tripod heads.
Thanks everyone for your help!
Ken
