Toshiba television won't change from Cable (VHF) to TV (UHF+VHF) mode
Steve P
The +/- buttons on a Toshiba CF19G32 television from 1998 will not
change its Setup screen's TV/CABLE mode to TV. It is stuck in STD
CABLE. These buttons also do not work on that Setup menu's CH PROGRAM
(channel programming) or ADD/ERASE. But these buttons do work on
other menu screen's for other operations such as contrast, brightness,
color, etc. so the buttons themselves are not defective. Also, on
the Audio menu, the buttons will not change the STR/MONO item but they
do change the BASS, TREBLE and BALANCE items.
It may have always had this problem as I have been connecting its
antenna through a VCR and then to the TV in which case the TV's CABLE
mode has worked to receive both UHF and VHF. I've only now directly
connected an antenna to the TV and discovered it will not show UHF
channels due to the above problem.
Andy Cuffe
Have you tried it from the remote? I've seen Toshiba TVs where the
front panel menu buttons don't work for all funtions. Some settings
could only be changed from the remote's menu buttons.
Andy Cuffe
[email protected] <-- Use this email address first
[email protected]
Steve Parus
The problem has turned out to be that the TV needs to have a signal
connected to its antenna input (and maybe TV selected instead of VIDEO
as its input) when doing this Setup. I can understand why it would
need a signal in order to activate the channel scan function, but why
also to choose what mode to use ?
John Hutchison
The TV does not know what you want to do till you give it a source.
kip
