Touch activated switch instead of Push to Make (PTM)
Dennis Gaida
Hi everyone,
this has been discussed a lot previously, but I still don't get the
point and I dont find the circuit for my needs.
I need a shematic for a simple Push to Make-touch activated switch.
THat means as long as I press the ONE sensor plate there should be
current flowing through the switch and power my system.
I found several promximity sensors or touch activated switches, but
still... not finding the circuit for my needs and experimenting around
is just not what I am able to.
I'm not able to use QTXXX (qprox) chips, since they are not available
here. So I just wanna use normal parts like this circuit shows:
http://www.uoguelph.ca/~antoon/circ/alarm2.htm
.... but it has a 5 second delay and I heard somewhere that it will
keep the relay triggered and all I want is to trigger it as long as I
push the button.
http://space.tin.it/scienza/fladelle/Page22.htm
....doh its 220V and I want it to be 12V max
http://home.maine.rr.com/randylinscott/sep21.htm
....another one, just too much to choose from.
I would be very happy if anyone could provide me with a quick
schematic of such a circuit. To get rid of the 5sec delay in the first
circuit I would have to get rid of P1, R1 and C1... but I wouldn't
know how to do that since there are still wires hanging around - So
could anyone provide me with a complete circuit for a push to make
touch activated switch?
Thanks in advance
Dennis
Robert Monsen
Dennis Gaida said:
Heard many other things... let's try that too :)
Why not use a Push Button? Simply because I dont want to. I could use
a microswitch which only needs the blow of the wind to trigger... but
why? Its just fair too easy and everybody has it :)
If you are going for cool, why not use a Sharp IR (GP2D120 for example)
sensor and let the wave of your hand activate the light? Its an easy
circuit, once you've built the frigging power supply that takes 120VAC ->
5VDC.
Regards,
Bob Monsen
Dennis Gaida
5VDC.
Regards,
Bob Monsen
Well that sounds interesting too, actually. Could you provide me with
a circuit. I admit I didnt look yet for circuits in Google, just for
the diagram and the chip seems to be intersting. Another way of doing
what I want to do.
Hope I get this proximitiy sensor working - what a mess.
Robert Monsen
what I want to do.
Sure. The GP2D120 takes 5VDC and GND, and outputs a voltage which is higher
when the sensed object is nearer. It senses between 10 and 30cm, I believe.
You need logic to detect the higher voltage, and to ignore little variations
when the value is changing.
The easy way is to connect the output to a PIC port set up as an ADC input.
I have PIC code to handle the ADC, and to handle the little state machine,
outputting a logic 1 if the light should be on, and a 0 if the light should
be off. Its really pretty simple, but I'll send it to you if you want it.
Email me at rcmonsen at comcast.net to get it. If there is more interest,
I'll post it.
The other way to do it would be to use a comparator with some hysteresis
(that is, positive feedback with a somewhat high value resistor), and feed
the output into a binary counter of some kind. A 4017 would work fine. The
output of the comparator then connects to the clock input, and the Q2 output
connects to reset. The logic output is Q1.
Both of these circuits output a logic value. You need to use the logic value
to turn on and off the light. You can do that by connecting up the gate of a
triac to the logic output using a 510 ohm resistor. Then, run the power
through the triac. See the data sheets for triacs for some application
information. Also, be careful about the triac you choose, making sure that
it is rated for the current you want to put through it. Also, I think triac
circuits won't be very useful with fluorescent lights, since they take lots
of power to start.
One hard thing about doing this is to get a stable 5VDC supply to run the
PIC or logic chips off of. See the thread on
alt.binaries.schematics.electronics for more information on how to do this.
The cheapest place to get GP2D120s is Arrow electronics, if I recall
correctly. They are around 8 bucks. They are fun for little robots as well.
Regards,
Bob Monsen
