Touch Light Goes Bonkers
W
W. Watson
I have one of those touch lights near our bed. If you touch the rod, it gets
brighter. Touch it enough and it turns off. Lately it's been turning itself on until
it reaches max brightness. Anyone know a cure for it? It doesn't seem to be touching
anything nearby.
Wayne T. Watson (The Wizard of Obz, Nevada City, CA)
(121.015 Deg. W, 39.262 Deg. N, 2,701 feet)
-- GMT-8 hr std. time, RJ Rcvr 39° 8' 0" N, 121° 1' 0" W
(Formerly Homo habilis, erectus, heidelbergensis and now sapiens)
"One advantage of being disorderly is that
one is constantly making exciting discoveries"
-A.A. Milne
Web Page: <home.earthlink.net/~mtnviews>
Tom Biasi
Hi Dubya,
Check for corrosion between the touch parts and AC ground. Loose wire nuts
perhaps; or a failing unit.
Sometimes bugs die near the light and make contact with ground.
Tom
Lou
Some one near you could be using a transmitter as well, that may be causing
it. If I recall correctly, there is "a" type of filtering you can use to
cure it. You would have to find an ARRL RF Interference Handbook to see what
it calls for.
Lou
