innovate.invent
- Jan 11, 2010
- 11
- Joined
- Jan 11, 2010
- Messages
- 11
Hey all, so years back I bought this transformer that was supposedly for an arc welder. It came with no documentation or identifying marks what so ever. I keep coming back to this thing trying to learn more from it so that perhaps one day I could start a DIY arc welder project for shits and giggles. I saw similar projects using a microwave transformer but would rather use the real deal.
Anyhoo!
So heres where I am at:
-I have a transformer with three separate coil pairs on the same core leading me to believe that it is a three phase transformer.
-Each coil pair (primary/secondary) is tied together making it almost look like a single center tapped coil if it weren't for the significantly different gauges of the windings. From this I can only guess that it is intended to be in a star-star configuration with a common neutral.
-I tried to hook the primary of one of the coil pairs up to a 116V supply and it blew the 30A breaker instantly.
-I hooked up the same coil in series with a 65W light bulb and got roughly a 0.8V drop across the coil
-I then hooked up the same coil again to a 12VAC supply and it cranked out 9.6A before starting to burn out.
the best I could calculate is that this thing wants to draw somewhere between 40A and 60A unloaded on a 116V source.
Does this mean that the transformer has a nasty internal short or is my lack of understanding of how a transformer works messing me up. Am I having these problems because I am not running all three phases at once?
I was told to put a variable resistor in series with the transformer and balance the voltages across both of them to get the impedance but I cant find a ~2ohm 7200W+ variable resistor
I could just go and hook this thing up and see what happens, but then again I could also just take a sledge hammer to my phase converter. I would rather do a bit of testing first to see why its drawing so much current with an unloaded secondary. Does anyone have any ideas?
Anyhoo!
