K
Kasamiko
- Jan 1, 1970
- 0
I got this audio amp without its power transformer. Based on the rectifier and capacitor connection it uses a CENTER-TAPPED transformer of about 3.5 amp.
Now my problem is, what might be the approximate secondary AC output (unloaded) of the transformer? The secondary filter capacitors are rated at 4,700uF/35VDC. Is it safe to assume an 18-0-18 volts secondary? ???
The output transistor used are TIP41 and TIP42..
Any help will be appreciated. ;D
rhonn
rhonn
