TrippLite Inverter PV-550 need schematic or value of fuse resistence
JG
I have a Tripp Lite Inverter model PV-550 and it has blown a big fuse
resistance I think it is 1ohm but I am not sure, does anybody have an
idea how I can fix it?
Thanks.
DaveM
JG said:
Thanks.
Fuses aren't identified by their resistance, but primarily by amperage, then by
voltage.
What are the numbers/characters on the base or body of the fuse? That is the
overall size of the fuse (length x diameter)?
Dave M
MasonDG44 at comcast dot net (Just substitute the appropriate characters in the
address)
"In theory, there isn't any difference between theory and practice. In
practice, there is." - Yogi Berra
Michael A. Terrell
voltage.
Newbie! Fusible resistors used to be quite common. They were rated
by resistance, and wattage.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
DaveM
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
I, sir, am NOT a newbie. I interpreted the OP's description as a FUSE, which he
stated it to be. Fuse was the first noun that he used in his description of the
part, which I took to be what he was trying to identify.
FYI, I've been in the electronics repair, calibration and engineering world for
about 50 years. Guess that disqualifies me as a newbie.
Michael, I used to like to read your posts, because they were always on topic,
and well written. However, lately, you have become very abusive in your posts,
making usually unwarranted flaming remarks and antagonizing those who are here
asking and replying to questions.
I know you don't give a damn about how I feel about you, but good friends are
hard to come by in most of these news groups. You obviously aren't trying to
make new friends, and it seems that you are quickly alienating those that you
had. I understand that you're disabled, but that doesn't give you the right to
blast everybody that might have a different view than your own.
Goodbye, Michael.
Dave M
North Florida
address)
Michael A. Terrell
Ok, you're not a newbie. Then you should have explained what a fuse
resistor was, and why you did't think that was what he was talking
about.
Goodbye, Michael.
That's your choice, as always.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
AJ
Highly suggest trying to determine what else has failed in the invertor, the
fuse resistor devices normally do not fail by themselves. Determine if those
devices are readily available and are exact replacments, then put your
ammeter in series with the circuit, determine the current draw while
measuring the applied voltage. Simple calculation should give you the
required resistance and wattage of the fuse resistor needed. I do not think
TrippLite will furnish even a basic parts list let alone the schematic.
