trying to find the perfect dc dc voltage current regulator
oved onto a new boat. I have incandecent light and would like to modify to LED. Havent been on the web in years and still having a difficult time with searches.
I came across the LT1618. Seemed good both current and voltage regulation. Looked up individual white light LEDs 3 watt and 5 watt.
5 watt LEDs voltage 3.8 volt. Two in series will drop 7.6 volt. 800mA each = 1600mA. Another set of LEDs put together in parallel.
Add in the pwm ability and the perfect boat lights.
and to try to make each light for under $15 is this possible?
Thank you Wiley
Thanks for the correction.
last time I used maxim ics and only 20 mA LEDs about 5 years ago. Forced retirement tumor on my spine. Now I have time play just not as much money to play with.
Thank you Wiley
Thank you Wiley
Thank you David. The already assembled package will be far easyer than the discrete IC + parts + board.
Wiley
