TV antenna amplifier power injector
eug k
I'm trying to hook up an active antenna that needs 5V at 30ma to be fed
thru the coax, to a tuner that doesn't provide that power. I'm
assuming I would be able to just hook up a 5V supply (from a USB
socket in this case) to the coax, with a capacitor between the centre
conductor and the tuner input.
Will this affect anything adversely? Is there a better way to do it?
I wouldn't expect the weak RF signal to affect the computer much, but
who knows. :)
The antenna will be mounted indoors near a window so lightning or
surges shouldn't be too much of a problem.
I thought of modifying a 2-way passive splitter for this purpose.
What cap should I use?>
I'd like to receive VHF and UHF, from 170-230MHz and 500-600MHz.
It's a digital TV receiver if that makes a difference.
thanks!
Phil Allison
"eug k
** The 5 volt DC power MUST be fed onto the co-ax via an RF inductor.
This is to isolate the PSU from the RF signal.
A value of 5uH should be OK.
......... Phil
eug k
Phil Allison said:
"eug k
OK.. what about the capacitor?
thanks!
eug said:
who knows. :)
thanks!
eug
Keep the inductor lead which connects to the RF path very short.
steve balstone
stephen balstone
ehsjr
eug
steve balstone
stephen balstone
What inductor? Why keep the inductor lead short?
Ed
