Twisted wire supressing output?
I am hoping that the experts on this board can answer this question.
I have a Robotic lawnmower that uses a radio signal radiated by wire
loop to both keep the unit within a boundary as well as provide a guide
for the robot to follow while trimming the perimeter. This is similar
to a dog fence as far as the signal generation goes.
Any required splices are by means of silicone filled wire nuts.
My questions:
Will a twisted wire splice cause any degradation of the signal?
If yes, could anyone recommend a better way of splicing the wire than
wire nuts aside from solder?
Any thoughts on lightning protection?
RR
martin griffith
On 12 Aug 2005 12:22:14 -0700, in sci.electronics.design
My questions:
probably not if it has a couple volts across it
screw terminal blocks,welding, if its clean and dry, almost anything
don't stand under a tree in a storm
RR
martin
me
Is it just me, or does an unmanned, self-propelled piece of (sharp)
rotating machinery sound like a really bad idea?
just you, sounds great to me...
Ross Herbert
My questions:
RR
Use 3M Scotchlok gel filled splice connectors
http://www.3m.com/market/telecom/access/pow/connector_chart.jhtml
As for lightning protection for your wiring loop, I don't think their
is much chance of getting a lightning strike if it is only a couple of
feet above ground. If it did get a strike it would be destroyed no
matter what protection you fitted.
John Popelish
My questions:
Any kind of splice will allow the system to work. The only thing you
have to consider is if the splice is moisture proof.
My son has a dog fence around his property and had the fet drivers
zapped a couple times by nearby lightning strikes before he added some
transient suppressor diodes like Digikey part # 1.5KE12CADICT
http://www.diodes.com/datasheets/ds21503.pdf
one from each end of the loop to the local receptacle ground. This
also protects the power supply from being arched across its insulation.
After a year with lots of lightning, it has survived, unscathed.
John,
I would like to keep lightning spikes outside the walls. Do you think
that I could run a line to the ground spike outside instead of a
receptacle?
To "Me" who thought ithe mower was a great idea:
probotics.com
RR
Rich Grise
John,
receptacle?
probotics.com
Just enclose the house in a Faraday cage. ;-)
Cheers!
Rich
