Two power supplies, switched by loss of one
mike sessi
Feb 20, 2016
9
Looking for, how to build, locate, create a solution
The problem:
I have many systems that need 12vdc at 6a.
When the PS fails, someone needs to drive to this locate and swap out the PS, this could take a day or more
The idea:
Monitoring the PS(A) 12vdc out. If the 12v goes beyond threshold
..the relay turns off power to PS(A) turns on PS(B)
Maybe a timer, wait 5 minutes before switching to PS(B)
USB sends a "1" ( or stops sending a '0')
Problem, when PS(A) fails, there is no power, other than 110vac
Use a battery or capacitor to power the circuit ?
When PS(B) is powered, 12v and/or USB 5v is available
The system will notify that PC(A) not working....be replaced when convenience.
Arouse1973
Adam
Dec 18, 2013
5,178
Why does the PSU fail? Fix that and that will save you time and money wont it.?
Adam
mike sessi
Feb 20, 2016
9
The P.S. has a life span of 3-5 years. These are off the shelve 12v/6A supplies.
Yes, a better supply would last longer, and this is what they use. Yet, An IP power switch (110v) could work ....off the shelve item
