Two Zener diode with parallel & reverrse connected to battery
Joonhwan Lee
Hi. I'm a newbie to electronics.
I have a interesting in zener diode that i think i can use it for
low voltage cut off of my rechargeable lithium battery(3.6V working
voltage).
I thought zener works like a resistor of high impedence under 0.7V in
forward
direction. So, I connect two zener diodes parrel connect with
different direction and one of its ends to my battery's (+) ve pin.
|_
(1)---+ +---| |-------(2)
| |_ |
But, it doesn't work the way I thought. What happen?
The zener diode that i used is 1.0W-5.1V
Thanks for your kind reply.
Soeren
Hi Joonhwan,
voltage).
Sorry, but not in this way.
forward direction.
Yes.
|_
| |_ |
The lower zener drops the voltage to (1) 0V7, while the other does
nothing at all (assuming you do not charge the battery through it).
When anti-paralleling zeners, they works just like if you used ordinary
diodes.
Regards,
Soeren
* If it puzzles you dear... Reverse engineer *
New forum: <URL:http://www.ElektronikTeknolog.dk/cgi-bin/SPEED/>
