tempus fugit
- Jan 1, 1970
- 0
Hi all;
I am using a ULN 2003 (multi darlington array relay driver IC) to drive
several relays for an audio bypass application. I'm getting some popping
when the relays switch, and was wondering if ramping up the control voltage
would help to reduce or eliminate this problem.
To achieve this, could I simply put a cap (say 0.1uF) across the across the
input and output of each Darlington pair? I have a data sheet of the ULN if
you need to see one.
