ULN2803A (darlington array) anyone know what I'm doing wrong?
Ben
Applying 5V to the inputs (power supply is also 5V), I'm only getting
0.6V at the outputs. I thought it was a faulty chip, or perhaps damaged
while soldering, but I've tried another one in a holder and got the same
result. What could be causing this?
Eeyore
How is it connected ?
What voltage did you expect to see ?
Graham
Phil Allison
"Ben"
Applying 5V to the inputs (power supply is also 5V), I'm only getting 0.6V
at the outputs.
** That is correct operation for a transistor in common emitter mode.
Input high causes output to go low.
I thought it was a faulty chip, or perhaps damaged while soldering, but
I've tried another one in a holder and got the same result. What could be
causing this?
** What the hell did you expect ??
The ULN 2803A darlington array is intended to drive relays, lamps, LEDs etc.
YOU connect one side of the load to + supply and the array will connect the
other to 0 volts when driven on.
........ Phil
Peter Bennett
A ULN2803 is just a bunch of Darlington transistors, emitter to
ground, and collector to the output pin. They are inverters, so a
high (+5V) input will produce a low (near zero) output. Also, the
things don't have anything to pull the outputs high, so, unless you
supply an external pull-up (such as a resistor to +5V), a low input
will also produce a low output.
Peter Bennett, VE7CEI
peterbb4 (at) interchange.ubc.ca
new newsgroup users info : http://vancouver-webpages.com/nnq
GPS and NMEA info: http://vancouver-webpages.com/peter
Vancouver Power Squadron: http://vancouver.powersquadron.ca
Phil Allison
"Peter Bennett"
** It won't be near zero volts.
The voltage drive for the base of second device in the darlington pair comes
from its own collector - so it will be at least 0.6 volts even at very low
current.
The data sheet gives saturation values for Vce up to 1.6 volts at 350 mA.
http://www.datasheetcatalog.com/datasheets_pdf/U/L/N/2/ULN2803.shtml
........ Phil
Ben
Thanks for the explanation, I think I'd misunderstood what a Darlington
array actually is. I was expecting a high input to produce a high
output, with enough current to drive relays. Does such an IC exist?
What value of pull-up resistor would you recommend for the Darlington array?
This is a perfect chip to drive your relays, the coil goes between the
output and posative supply. You may find a circuit somewhere on the
data sheet or do a search.
Eeyore
Do you know what a transistor does ?
You're fixated on 'ICs' aren't you ?
What do you need a pull-up for ? The load *is* the 'pull-up'.
Graham
BobG
Be nice. Or just dont say anything. Some patient person will explain
politely.
Ben
I'd need 8 transistors, so a single chip that does the job seemed like a
good idea.
Ben
Yeah, this worked great - thanks :)
Jamie
array?
you don't need a pull up resistor..
use the Array outputs as the Common/ground source when on.
they are simply what is called open collector outputs.
you can supply the relay coil with what ever voltage is required by
the relay up to the max stand off voltage of the array of course.
the + side of the relay coil does not need to be the same voltage
as the Vcc (+ rail) of the chip..
Jamie
Graham
Graham:
the last time i looked at the name on this NG, it said "BASICS"!
where i come from that means something. maybe you should show a little
consideration for others that are at least trying, and not criticize
at every turn.
(Just an opinion from the peanut gallery)
jasen
that's about right.
probably you're using it incorrectly.
the load should be connected between the output and a positive supply.
