Unbalanced to Balanced ?
Chris
My guitar pre-amp has no balanced output .
The main amp I want to use only has a balanced input .
Input instructions of the main amp say :
Tip - hot .
Ring - Return .
Sleeve - Earth .
I guess my only option is to connect the pair with a standard mono jack to
jack .
Tip - hot , Sleeve - Earth/Return .
Will this be OK ?
What am I going to lose out on ?
Chris
Ban
Tip - hot .
Ring - Return .
Sleeve - Earth .
jack to jack .
Will this be OK ?
yep, you can try first like you said. But if there is a hum in the line
because of some ground loop, it will be better to use a DI-box. This box
contains a small transformer, so both amps are galvanically isolated.
Bob Masta
Tip - hot .
Ring - Return .
Sleeve - Earth .
jack .
Will this be OK ?
Chris, are you sure the amp input instructions
are really talking about a true balanced input,
or maybe just a normal single-ended input
with a separate shield? The shield would
then be connected to ground at only one
end to prevent ground loops.
Best regards,
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
Home of DaqGen, the FREEWARE signal generator
K
Kitchen Man
Tip - hot .
Ring - Return .
Sleeve - Earth .
jack .
I wouldn't do it that way. Connect tip-to-tip unbalanced-to-balanced,
connect the sleeve of the preamp to the ring of the main, and leave
the sleeve of the main floating at the preamp. Use shielded
twisted-pair for the connection. As another poster mentioned, the
best way is to use transformer isolation, but I think you don't have
that option. If you tie "earth" and "return" together in the
connecting wire, you will probably have a ground current loop, and
hence, hum.
K
Kitchen Man
Use shielded
A clarification - you can use triax, if that's what you already have.
The point is that you use a three-conductor transmission line. I
don't think cable characteristic impedance will be a problem with your
planned low frequencies and short runs.
