Hi, I have a CRT monitor that has a small circuit board for controlling monitor adjustments. Basically, this board holds 5 switches and 2 LED indicators. It communicates with the monitor using some type of serial protocol. I could really use some help understanding this circuit. Ultimately, I am trying to interface with the monitor using a serial port. By "interface," I am talking just about the control protocol, not video. Video is through regular VGA. Unfortunately I lost the board while building a project, and I need some way to control the monitor.
I've attached 3 pictures of the board. Sorry there is a little bit of glare in them. I know it makes it difficult to read some of the labels. The board is really well labeled, which definitely helps. I'm a mechanical engineer, so please forgive my spotty understanding of this circuit. I'll try to sum up my investigation so far.
* There are 6 lines: 2 are ground, 1 is +5V, 2 are for the LEDs, and the final one is labeled "KBD1." I assume this is a uni-directional serial data line. The monitor sends the LED commands on dedicated wires, but the control board sends commands via the KBD1 line.
* There are 5 buttons: power, up, down, 1 and 2. The power button just turns the monitor on and off. The up and down buttons move up and down through the on screen menu. The 1 and 2 buttons are context sensitive, but generally 1 is OK and 2 is cancel. Pressing the 1 button brings up the menu. All of the monitor control functions like geometry, color temp, brightness/contrast, and de-gaussing are in these menus. There are no other buttons on the monitor.
* There are two transistors and one diode, and all the of other components are passive RLCs. There are no ICs. From this, I assume that the serial protocol is a pulse length encoding. Since there are 5 buttons, I imagine there should be 5 commands. It seems that the KBD1 line is normally high, then when a button is pressed is, it goes low for some time determined by the resulting RLC circuit. Does anyone know if this is some sort of standard protocol? I don't know the values of the inductors or the capacitors, so I can't really analyze the circuit to see what the time constants should be. Honestly, even if I had all the values, I'm not confident that I could calculate it correctly.
If anyone is willing and able to share any more insight into this circuit, I would greatly appreciate it.
Regards,
James
Regards,
James
