unknown components specs / datasheet
3rq8
Aug 16, 2009
Hello everyone.
I'm looking for information on some unknown components, i suspect these are dual transistors or similar (i could be wrong though), the components are listed below, i also included a brief description and / or the data i could find on the net:
150DT2 (THOMSON / metal can enclosure / 7 pins / dual (?) transistor (??))
TIC60005V (metal can enclosure / 8 pins)
The info i could find on the net was from distributors / retailers of obsolete components, anyway, there were no specifications whatsoever, so i will be most grateful for any relevant info on these (component description, pinout, specifications, spec sheet, datasheet, anything will do).
Thanks a lot for your help.
3rq8
fzabkar
Oct 18, 2009
12
All I could find on the TIC60005V is that it is an "OPTO_TO39" made by both Toshiba and Texas Instruments.
Resqueline
Jul 31, 2009
2,848
TIC60005V 8 pin TO39 metal can OPTO? Could it be an opto-triac? Fascinating!
The other device also sounds like a thyristor or triac, just by the name of it, but I never saw them in metal cans before.. 150 might be the voltage and 2 the amperage.
It seems you'll have to measure and test them a little to find out more.
er.egypt
Aug 27, 2011
about 150dt2 ( metal case) available in the market
manf. SGS THOMSON
