W
Will Waterston
- Jan 1, 1970
- 0
I am building a small circuit that uses this 4093 ic, but I am only using
pins 1-7 and pin 14 of course for power. Pins 8-13 are not being used.
What should I do with these pins? Since I am using a socket, I was going to
just clip these pins so they wouldn't be part of the circuit board and just
solder in pins 1-7 and 14, but now I'm coming across readings that there
should be no pins left open with this IC since it is CMOS. Can I leave
these pins open and, if not, should I just ground them or pull them to
ground with a 3-5K resistor?
Thanks in advance,
Will
Thanks in advance,
Will
