Y
Yukio YANO
- Jan 1, 1970
- 0
I am puzzled by a dead audio output stage using a uPC1242H ! DC
checks shows 12 Volts on Pin 8 (supply) but Pin 6 (audio OUT) shows 0
Volts (should be ~ 6 Volt ie 1/2 Supply), Pin 1 (audio IN) is 0 Volts
with ~ 1 V pp Audio
Pins 4/5 are at Grounded . Resistance Checks, Out of Circuit on New
IC's and compared to original are identical. Re-installation of new ICs
show exactly the same response 0 Volts on pin 6 ! There is not a hint of
a signal on pin 6, should show something even into a Dead Short.
What am I missing ? Pins 2,3,7 are all around 1~2 Volts.
Do I have Three Dead Chips !, I haven't seen that many failures at one
time in years ?
I always check for a bad Audio Output Chip by measuring the Audio Out
Pin and expect it run at about 1/2 Supply Voltage.
A circuit diagram would be nice, but I think the problem in "on chip" so
a diagram is really not that helpful.
I guess I am just having a bad day !!
Yukio TIA.
with ~ 1 V pp Audio
time in years ?
Yukio TIA.
