UPDATE: Most Common Problem With Floppy Disk Drives
Brad
One problem floppy drive in a laptop, I hear a "wine" noise (belt slip)
during an attempt to read a floppy. I removed the floppy drive and checked
it. I removed the belt and cleaned it with a rubber cleaner/revitalizer.
Afterwards, no more "wine" noise and the floppy drive can read/write now.
I would like to buy a new belt, but this belt is very small in thickness
(can't use any other type of belt), and I doubt I can find a source that
sells them.
Brad
H
Homer J Simpson
thickness
sells them.
Try a hydraulics shop for o-rings and other seals.
rebel
sells them.
Here in Australia we have a trade shop which supplies repairers with components,
and they have an extensive range of circular/square/flat drive belts for audio
etc gear. I'm sure there are similar suppliers over your side.
Michael A. Terrell
Brad said:
sells them.
A floppy drive with a belt, and in a laptop? I haven't seen anything
but direct drive motors in floppy drives, since the 360K full height
5.25" drives went away. Who made the drive, and what is the model
number?
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Michael Black
number?
I'm sure I've seen belts in 3.5" laptop drives, but they'd date
from a time when the floppy drives were the only storage the laptop
had.
Michael
budgie
number?
My AcerNote Lite laptops use external floppy drives which have a belt drive.
I suspect it is done to achieve a low profile (although why a low profile
matters on an external drive is a mystery).
Michael A. Terrell
had.
Michael
I've seen hundreds of 3.5" drives, including the early full height,
but never one with a drive belt.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
bz
For belts, I have been lucky here. Menu on left side: Belts
Where is 'here'? I don't see any menu on the left side of my screen. I am
using xnews to read the sci.electonics.repair newsgroup.
I am guessing that you are using google groups or some other way of
reading news groups, but you need to keep in minds that many others are
not doing so and are not seeing the ads that you are seeing.
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam trap
Michael A. Terrell
There are no URLs in his message. He must have forgot to paste them
in.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Gary Tait
number?
I had a Toshiba Satellite 100 (I think). It was a PI-75, with a 540 MB HDD.
Its floppy drive spindle was belt driven from a DC-PM motor.I think though,
the slightly newert Laptop I have has a direct drive floppy.
