use of American AC POWER ADAPTER in France?
This is pretty simple. I have a Samsung AC Adapter for my laptop
computer. I am using it for the first time in France and have been
plugging it into a standard 50 watt transformer to convert the
electricity from 220 to 110.
I notice however, that printed on the computer's AC Adapter is:
Input: 100-120V/200-240V ~ 1.6/0.8A 50/60Hz
Output: 16V ------3.75A
Is this designed to be able to be plugged in directly in both the U.S.
and in Europe?
I'd like to be using the one transformer that I have for something
else, so if I don't need to use it with my computer, that would be
great. But, I don't want to plug in the computer's power supply
directly without being sure that it will accept the 220v (obviously).
Any info would be appreciated.
Best!
HM
Tom Biasi
and in Europe?
Best!
HM
Your supply was definitely designed to run on 220/50 or 120/60. How you make
the change is the question. Is there another power cord that fits the Euro
power?
Is there a switch on the unit?
Regards,
Tom
Don Bruder
It's simpler than you realize, I'm thinking :)
From what you say about the label, it's electrically good to go. Plug it
in directly (If it's physically compatible with french style sockets...
You may need some sort of adapter - blades to pins, pin/blade
position/number/orientation, etc - for that part), and it should "just
work".
Yes, I will have to get a plug converter, blades to pins as you say.
But otherwise, electrically, its good to go? This is what I suspected,
but not knowing anything about electricity I thought I'd ask.
Thanks for your response!
HM
I think all I need is a plug adapter so that I can just plug it in (see
Don Bruder's response). There is no switch on the computer, but it
looks as thought the AC adapter will accept either 110 or 220 and
convert as necessary.
There is no other power cord. The adapter has two cords, one exiting
at each end; one terminates in the plug and the other is inserted into
the computer. It appears that both are permanently joined to the
adapter.
I'm going to try it and hope that nothing fries.
-HM
Martin D. Bartsch
There exist power adapters with a range from 90 to 250 V input, so if
it is marked on the unit it should work.
Rich Grise
Before I just plugged it in, I'd look very carefully for a changeover
switch, somewhere near where the mains power cord enters the brick.
If it's there, it'd be a little rectangular recess with a slider at
the bottom, with a slot in the slider so you can switch it (it's
a slide switch with the knob lopped off) with a tiny screwdriver.
It should also be marked 110 on one side and 220 on the other (or
something to indicate the range). If there really is nothing like
this, and it really is clearly marked like you said before, then
it should work. Worst case, you'd only blow the fuse anyway. :)
Good Luck!
Rich
