AIMatrix
- Jan 1, 1970
- 0
Can I control a SSR with the out put from a Triac and still do phase control
for dimming??? Andy
for dimming??? Andy
AIMatrix said:Can I control a SSR with the out put from a Triac and still do phase
control
for dimming??? Andy
AIMatrix said:Can I control a SSR with the out put from a Triac and still do phase control
for dimming??? Andy
control for dimming??? Andy
Hi Chris; I am trying to make an add on for an existing light controllerChris said:Hi, Andy. I'm not sure where you're coming from here. You're saying
you're already using a triac for something, and also want to drive an
SSR with the same signal? Why not just drive a second triac with the
signal driving the gate of the first triac?
By the way, you can use an SSR for lamp dimming as long as it isn't a
"zero crossing" drive model. Those wait to turn on their internal
thyristor at the zero crossing of the AC line, which means by
definition they won't do phase control.
I'm not sure this is responsive, though. Could you please explain your
problem in more detail?
Chris
Homer J Simpson said:Is the SSR rated for dimming service?
=----me said:it's ok by me...
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption
AIMatrix said:Hi Chris; I am trying to make an add on for an existing light controller
that has 8 triac outputs for dimming. It is limited to 8 amps max per
channel or 15 amps total. I want to plug a high power SSR in to it using a
separate mains supply to get a
20 amp output. This is only needed some times and on random out puts so I
would rather not change the existing controller.
I have been looking at this for days now and have not found any info
directly pertaining to this but have found the best high power switching is
done with inverse parallel SCRs, but have not had any luck figuring out the
gating. Most of the circuits that I have found just leave the gates hanging
with no other circuitry. Some show the two gates connected together thru a
triac, but non show phase control with 110VAC.
Finely I found a vender that makes a random turn on SCR SSR with 110VAC
input, but they are not common and are hard to get and expensive. Not
knowing if it will really work for what I want it to do a rather not spend
the $30 to find out.
I rather roll my own out discreet components but have hit a wall with the
gating circuitry.
Can you be of any help??
Thanks Andy
is
Homer; could you explain this?? Would it work if controlled by a triac???Homer J Simpson said:That used to be true and was common practice for stage dimmers 30 years ago.
It doesn't really apply these days.
To fire this circuit needs a 3 winding pulse transformer.
ehsjr said:AIMatrix said:Hi Chris; I am trying to make an add on for an existing light controller
gating circuitry.
Thanks Andy
Let me see if I understand what you want to do:
| Existing |____________________
| Controller |8 outputs to lights \
| Includes |____________________/
| Dimming |
You want to plug in to one of those outputs and do this:
Output (AC)----+---------+
[SSR] [Light]
The SSR needs to operate whenever the light
is on, even if the light is dimmed. Assuming
that is correct, all you need to do is sense
the voltage to the light, and use the sensed
voltage as a signal to a circuit. The circuit
merely needs to detect the signal and turn on
a triac/SSR/SCR's whatever when signal exists.
You could AC couple the signal from the a wall
wart or current transformer to a comparator
and use the comparator output to control
whatever. You need a separate power supply
for the comparator
The following assumes your existing controller
can handle inductive loads:
Plug an AC output wall wart (in parallel with
the light) into the controller.
The output of that wall wart will provide input
to the separately powered circuit - in other words,
you are not using that wall wart to power the
second circuit. The wall wart is just to isolate
and reduce the voltage.
If your existing controller cannot handle inductive
loads:
Make an "extension cord" with a line cord and plug
and an electrical 4" junction box and receptacle. One
lead of the line cord passes through a current transformer.
AC --------------| | | |
| o |
Ground ----------| 0 |
| o | |
------- [C | T]
AC ------------------------------+
The 2 wire output of the CT gets connected to
a resistor. AC couple the signal developed
across the resistor to the comparator.
Ed
Homer; Thanks on the tip of UJT I will look into it and yes I would love toHomer J Simpson said:triac???
You need to use a pulse circuit, like a UJT or the like. You can do it with
two transistors. Look in your library for a GE hobby or SCR manual. But
really, a triac is way easier.
to
get my hands on the GE SCR book. I have seen many references to it over
the
last few days researching the problem. According to the library index the
closest copy is in an university 90 miles away. Could not find an online
copy but they may still be available to buy. Andy
control
for dimming??? Andy
Chris
athat has 8 triac outputs for dimming. It is limited to 8 amps max per
Iseparate mains supply to get a
iswould rather not change the existing controller.
thedone with inverse parallel SCRs, but have not had any luck figuring out
hanginggating. Most of the circuits that I have found just leave the gates
awith no other circuitry. Some show the two gates connected together thru
spendtriac, but non show phase control with 110VAC.
thethe $30 to find out.
gating circuitry.
Thanks Andy
| Dimming |
[SSR] [Light]
for the comparator
loads:
| o |
| o | |
------- [C | T]
Ed
Ed; You are close, but I would not have a light on the input side of the SSR
and the SSR would have its own supply.
ehsjr said:AIMatrix said:usingAIMatrix wrote:
control
for dimming??? Andy
Chris
controller
a
switchingseparate mains supply to get a
I
is
thrudone with inverse parallel SCRs, but have not had any luck figuring out
the
hanging
a
spend
the
gating circuitry.
Thanks Andy
| Dimming |
[SSR] [Light]
for the comparator
loads:
| o |
| o | |
------- [C | T]
Ed
Right - the SSR gets *power* from its own supply.
It is *controlled* by sensing power from the existing
controller. The wall wart or current transformer AC
coupled to a comparator should do it. If you use the CT,
you must have a load powered by your existing controller
on the channel you are sensing, but since you will have
no light there, you'll need to provide a load. And
since you would have to provide a load, you don't need
a CT - just use a resistor divider and sense the voltage
across the smaller resistor:
| Existing |---[1K]---[1K]--+
|Controller| |
| Neutral>|---+---[100R]---+---[.1uF]---> to comparator
---------- | input
+--------------> to comparator ground
Neutral side of
controller output.
Use 10 watt resistors for the 1Ks, and a 5 watt resistor
for the 100 ohm. The 1K's will dissipate ~ 4 watts each
and the 100 ohm will dissipate ~ .4 watts, worst case.
Use a transformer type (not a switcher) supply for the
DC to the comparator.
Ed
AIMatrix said:usingHi Chris; I am trying to make an add on for an existing light
controller
switchinga
I
thruis
the
hanging
SSRa
spend
the
gating circuitry.
Thanks Andy
|Controller| |
---------- | input
Neutral side of
controller output.
Ed
Do You think that would work with the phase controlled dimming ???
