Robert A Moeser
- Jan 1, 1970
- 0
hi!
i want to replace a wallswitch with a triac and a PIC. i have a working
circuit using a triac, an opto-isolator and a PIC.
i have access to only the two wires in the wall switch, so for now the
PIC power supply is a battery. can you say "yuck"?
i would like to have 5 volts at, say, 15 mA available in the wall switch
using mains power only. i think this is possible, as i have a commercial
motion detector wall switch, using a Holtek HT7611, and it connects only
where the switch would have been.
i posted a schematic on ABSE from the HT761X data sheet, all of which i
found at
http://tinyurl.com/ne95
i see (sort of) how it develops a local low voltage DC supply for the
electronics when the triac is off. what i don't see is how it continues
to do so when the triac is on.
in any case, it seems to do something like what i need. have you a
similar circuit or an idea of how the Holtek version works i can exploit?
-- rob
found at
-- rob
