Eric Livingston
- Jan 1, 1970
- 0
I have three speaker wires running just behind sheetrock along a wall in my
house that have breaks in them somewhere (I believe from the contractor
firing nails through the wires when putting up the sheetrock). Two of the
wires are shorted from one end (wall terminal) and open from the other. The
third is open from both ends. I figure in all cases a nail-gunned nail went
through the wire in question, and in two cases the nail is probably shorting
one half of the wire.
I would like to detect where the breaks are in the wall.
I've tried generating emf in the shorted lines in the wall using a strong
magnet, and it works to a degree but not enough - I need a stronger magnet
or a more sensitive multimeter.
What I'm thinking now is that if I can use the wire(s) in the wall as an
antenna, generating some kind of signal, I could use a receiver held up to
the wall to detect that signal, and thus detect the break. Would this work?
How would I best do this?
Also, I've used a small electric motor as a generator to create an AC
current in the wires. This also works to a small degree even with the cut
(i.e. open) wires in the walls due to the capacitance of the wire, though
there's no closed circuit. Can I use something to detect the AC Current in
the wires behind the wall? Could this work even with the broken (not
shorted) wires, relying on nothing but the wire capacitance to allow a
trickle of AC current to get through?
Are there other ways to do what I'm trying to do? It seems like it should be
possible.
Eric
possible.
Eric
