Daniel Towner
- Jan 1, 1970
- 0
I am using a buck converter, based on the Zetex 300 to drive a 3V, 1A
Luxeon LED from a 4*AA battery pack (Zetex design note 73). I want to
be able to have some control over the output of the buck converter so
that I can vary the light output. It doesn't need to be that fine
grained - two different power levels of 1A and 300mA would be
sufficient. At the moment, the entire circuit is switched on and off
using a PIC 16F682 controlling a power transistor. Obviously I could
build a buck circuit based on the PIC itself, but is there some easy
way of modifying the Zetex circuit itself so that I can vary its
output? Could I use two current sense resistors of different values,
and use transistors to determine which one is used as the current
sense for the Zetex 300?
thanks,
dan.
thanks,
dan.
