VCR HEAD Glued??
Are the little protruding "tape readers" on the edges of the DAT/VCR
HEAD Glued on or Soldered on Etc.?????
Since I think manual cleaning of DAT/VCR Heads are the cleanest and
most efficient, they would alter the chemistry of the Glued on little
*protruding "tape readers"*......which would explain a few things...
N
N Cook
The makers would probably prefer the term "bonded" to glued.
They,VCR ones anyway, are positioned in a X,Y,Z sense to an accuracy of
better than 1 micron IIRC.
Sam Goldwasser
Normal cleaning won't damage the glue.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
|>> Triad Productions-Fantalla©~EZine~ParaNovel
|>> National Astrophysical Assault Research
|>> http://lacasse.naar.be http://ammo.at/lacasse
So I will refrain from using the Acetone except in lost cause
situations when all the repeated use of all the other solutions produce no
results....
I have rescued a few DAT/DDS/VCR heads that way, but it's delicate
work but used in Floppies takes a paper/no plastic disk cleaner ....works a
lot if you find a paper floppy cleaner....adds an extra couple of years of
use....like the DAT/DDS/VCR heads....but accidents do happen.......
I figured they'd be bonded like the 120 layers of a Travan Tape
Streamer head.....I use a lot of tape and drives....14 of them...no use in
changing the procedure for backups...since it's what I have, unless I wanna
backup or off-drive and try to put a laser disk in a Tape drive.....
Some people do backups on the parallel port of to a VCR using
Backer32 or similar...I think a full tape only holds 5 MB since it is analog
and only writes to the top video layer.
Thanx for the nfo...
