video surveillance
F
FrankLee
Does anybody know of a home video surveillance system?
I have a neighbor who has been periodically vandalizing our property
over the past 3 years. I want to set up a hidden camera system to
record him. The police said they can't do anything unless I catch him
on camera.
He does a couple hundred $ of damage per year. And I'm afraid for the
safety of my family.
My budget is about $300 but maybe can go higher. I have a good working
pc I can use for a system.
Any suggestions/ideas helpful.
FrankLee
David L. Jones
on camera.
FrankLee
You can get cheap PC cards designed for just such a purpose, like this
one:
http://www.jaycar.com.au/productView.asp?ID=QV3080
Probably get them (and the camera's) a lot cheaper on eBay.
Get a big mean dog (preferably two) as well.
Dave.
atec77
on camera.
FrankLee
All comes down to expectations
enay will supply a dvr ard to add to your pc , be aware the cheap ones
have only one controller chip and you need one per cam so shop carefully .
A cheap card ( under $100 ) will run at best one or two cams
shop here http://www.veelock.com.au if you want a decent cam or ebay
for anything else
divide the fps by the number of cams , less than 25fps will "stutter "
to some degree
expect to pay $150.00 for an auto iris auto focus unit .
go here > http://www.jknelectronics.com/lenses.htm
to calculate the lens needed
the more tvlines eg 480 means better image
240 lines is a rough and blurred picture
swanny
on camera.
FrankLee
At night or during the day? Or both?
Elmo
one:
Dave.
Why don't you go and whack him with a lump of four by two?
As a first time offender you can say you were provoked, it's your word
against his. Fines for assault are dismally low, maybe about $300 for a
few blows to the head, and your neighbor will know that you're not to be
messed with. It'll put him on the defensive, and the onus on him to
prove his case.
Elmo
Robbo
on camera.
FrankLee
look here: http://www.allthings.com.au/
David Shorter
on camera.
FrankLee
http://www.swann.com.au/ Available from Dick Smiths, etc.
Regards,
David Shorter
Any errors in tact, fact or spelling
are entirely due to transmission error.
Terryc
This mob are completely useless and totally clueless about their own
products..
They make a door cam/intercom with one or two handsets. First they tell
someone that you just buy two of the single handset models and you can
piggy back one onthe other to get the double handset version.
Then they say you can not do that with old models, but have to buy
another new double model, which isn't any good for an external door.
Then they go back to option one, then this , then that.
Frankly they don't have a clue. The dizzy limit was when they came back
telling me that you join two wires here from one handset and the other
two wires there from the other handset. Yes, but what about the other
two wires from each handset.. "Oh, there are four wires on each handset,
we''l get back to you" and I'm still waiting.
David Segall
I am inclined to agree. Their "Digital Private Eye"
<http://www.swann.com.au/s/products/view/?product=344> should be
exactly the product that the OP, and anyone else who wishes to
identify vandals, wants. After you find your property has been damaged
you would expect to see the last n minutes of motion triggered action
recorded where n depends on the size of the memory card you purchased.
You would be disappointed. After the memory card is filled, instead of
overwriting the oldest recorded frames, the device just stops
recording!
David Segall
atec77 said:
Much better to use the vivotek free software with a decent dvr card.
Maybe, but the "Digital Private Eye" costs less than two hundred
dollars and does not need to be connected to a computer. It includes
the camera, a motion detector, a memory card and firmware to record
the images. The image is adequate to identify a vandal from a small
population. The population is one person in the case of the OP and
restricted to members and their children for the vandals I wanted to
identify at our tennis club.
Our tennis club does not have a computer and installing one would be
costly and vulnerable to vandalism :( Although the "Digital Private
Eye" needs a computer to read the memory card the computer does not
need to be connected to the camera or even be on-site.
With a few hundred extra firmware instructions the "Digital Private
Eye" could be the ideal, cheap tool to identify vandals in many common
circumstances. I thought that their omission was enough to roughly
agree that "this mob is completely useless".
atec77
recording!
atec77
providing a very average image at barely usable resolution , seeing
the face and not just a blurred image is generally a good idea
It includes
identify at our tennis club. see above
a used PIII all that is required at less than $50.00 is all it costs ,
a dvr card able to provide good resolution from ebay under $50.00 and
the camera from veetech at maybe $120.00 plus a cable
Marc Noon
FrankLee said:
.......video camera blah balh Neighbor .. blah blah blah ... thief...blah
blah blah
Thanks, FrankLee
You could go to your local video survellience dealership and ask for some
professional advice. I think the trick is to have a triggering mechanism,
and a large hard drive that can record your neighbor's meanderings. Maybe
have it set up to scheduled times when you aren't home.
You could probably set up a system like this for about 1000 bucks with a
cheap 800 by 600 video camera, and pc combo. Platform sdk will allow you do
perform some crafy little diversions into the realm of vid surv software on
a microsft machine, and linux has ton's of free ware. Java has a ton as
well.
I think the only problem you might run into is switching your feeds if you
need more than one camera ckt.
Marc
John
on camera.
FrankLee
Cheapest is probably a webcam with motion detect software to only grab
stuff with motion. My Creative cam came with such s/w. I always
figured it would be good to have it ftp the evidence off-site in case
theives stole the cam and PC but if it's only outdoor vandalism you
can skip that nicety.
John
