Jeff Strieble
- Jan 1, 1970
- 0
Greetings!
I was nosing around on this group awhile ago and came across a
warning that should and must be heard, if you haven't heard it
already. The RCA CTC-185 XL-100 TV is a great set, once the issues
with the solder joints around the on-board tuner are corrected (I've
had one now for almost four years; it has a great picture, like a
picture postcard, on cable in my small town, even though I've already
had the RF port replaced--the technician resoldered everything around
the tuner when he put back the tuner cover after completing the
repair--haven't had any trouble with the tuner or EEPROM since, and
these repairs were made at least two years ago).
However, this set is not, I repeat not designed for use with external
loudspeakers connected directly to the audio output. The reason is
that the CTC185xx series is a hot chassis design; if the speaker leads
are shorted to ground for whatever reason, extremely serious damage to
the set will occur which will cost at least the original purchase
price of the set to repair. Moreover, anyone who comes in contact with
the speaker frame or terminals and ground will receive a severe
electrical shock and could even be electrocuted. If you want to use
external speakers with this set, run the audio output of your VCR
through an external amplifier and speakers, or else send that output
to a wireless headphone set such as are sold at Radio Shack. (I use
the audio output from my cable box and run it through my Aiwa
bookshelf stereo. Wonderful sound, especially when I listen to the
music channels on Comcast digital cable or music programs on PBS,
etc.)
Kind regards,
Jeff Strieble, WB8NHV
Fairport Harbor, Ohio USA
etc.)
Kind regards,
