Wattmeter failure
Andre Majorel
Left a 400 W dehumidifier running off a wattmeter. After a week
or two, the dehumidifier didn't work any more. The fan is on but
when the compressor tries to start, the display jumps to about
1200 W for a couple seconds, a click is heard (maybe a klixon)
and that's it.
The dehumidifier works fine without the wattmeter.
The wattmeter now reads 300+ W for three 36 W FT when it used
the read about 140 W.
Is this a well-known failure mode ? Bad shunt ?
Thanks in advance.
mike
and that's it.
Thanks in advance.
You've asked for help with the failure modes of a wattmeter while
giving no, zero, not any clues as to what kind of wattmeter.
It's like asking, "What's wrong with my car?" It doesn't work any more.
Andre Majorel
The only thing I can think of is to find out what inrush current is the
Wattmeter designed for. In other words is it rated for motors?
The manual only says 16 A / 3680 W (I'm not in 115 V-land).
Remember that a dehumdifier is a small regrigerator (with the door wide
open) and as such has a high initial current draw to get the compressor
motor started...
I'm sure someone here can answer the question of how much inrush
current/power to expect on a 400W dehumdifier, but at a guess I'd say 15
to 20A (1200 - 1500ish W).
So, yes, your shunt may well be compromised.
The shunt appears to be a cm-long piece of copper alloy wire, no
markings, CSA about 1 mm². When my free time becomes copious
again, I'll try to compare its resistance with a not-yet fried
unit.
Thanks everyone.
