Ways to remove black 'goop' over ICs on mass produced PCBs?
matt
Is there a 'safe' way to remove the black blob of goop which is often
placed over mass produced ICs on modern PCBs?
I just want to faff around with a failing circuit on a festive LED
cluster/decoration. Basically it's a cluster of seven LEDs (two
yellow, two red, two blue and one green in the centre) that vary in
intensity - it looks like the IC is controlling the voltage to the
LEDs (and hence the intensity).
Pooh Bear
Don't even bother. The 'goop' is there to protect the IC. You will simply
destroy it by removal.
Graham
matt
Was wondering if that was the case. Ah well, ta. :)
Tim Williams
simply destroy it by removal.
-Eh, some epoxy remover might work. You'll probably lose the circuit board,
connecting wires and IC in the process though, I understand epoxy remover is
pretty nasty stuff. ;o)
Tim
