Weird problem in Full wave (FW) bridge rectifier
I am working on implementation of FW bridge rectifier (without any
filter). I am applying a sinusoidal input (1 Phase, +- 20, 60 Hz) to
the bridge and measuring the voltage across the load resistance. When
I am trying to dispaly the output waveform in a CRO, I am seeing
only one half of the rectified waveform. I cross checked the
individual diodes and I found that all are in perfect condition and
working nice when using in HW rectifier mode. I want to know why I am
seeing such a wierd results.
Greg Neill
Where are you taking your ground reference from for
the oscilloscope measurement?
"YES"? That's not a helpful response.
I resolved the problem. I was using input signal from the function
generator of oscilloscope. I came to know that If you are feeding it
a signal (~) that goes from oscilloscope ground to
a positive voltage, there will be no negative part of the waveform
when we measure it with oscilloscope. I then tried a transformer's
output as the input and problem got resolved.
