Weller WES51 soldering station problem?
  • Thread starter Bill Christens-Barry
  • Start date
Hi. I have a Weller WES51 soldering station, an adjustable
temperature unit with a pencil iron (p/n PES51).
Last time I used it several months ago, it worked fine.
Usually, the light on front would stay green until the tip
reached the dialed in temperature, at which point the light
would start blinking green.
Now, when I turn it on I don't get any heat at the tip, and
the indicator light in front stays red. I'm trying to figure
out why.
The unit comes with a magnetic pencil-like thing that can be
placeed near a spot on front of the main unit. This spot is
labelled "ESD", so I guess this has something to do with
electrostatic discharge. When I put the probe there, the
indicator light first begins to blink in red, and then
starts blinking green. I still don't get any heat.
What's this all about? Is it a sign that the iron itself has
failed? Is there an easy fix short of getting a new iron?
And can anyone point me to an online (or hardcopy) version
of the manual?
Thanks.
John Popelish
out why.
of the manual?
Thanks.
Wm A Christens-Barry, PhD
Equipoise Imaging, LLC
[email protected]
http://www.eqpi.net/eqpi/
It sounds like an open circuit hearing element of wiring to the
heater.
Do you have an ohm meter to check the heater resistance?
John Popelish said:
snip
heater.
John,
Thanks for the good idea. I'll try to check this, although I
don't know which pair of the 5 probe leads are the actual
heater. Also, I don't know what the resistance should be.
Any data would be helpful, especially a contact for Weller.
John Popelish
Bill said:
John,
[email protected]
If the heater is powered by something near 24 volts, the resistance is
in the single digits. If powered by 120 Vac, then the resistance is
in the hundreds of ohms. The thermistor pair should be in the kohms.
One wire should be a short to the tip (safety ground). If you can get
the case open, it should be pretty obvious which pins on the socket
connect to what.
cornytheclown
out why.
of the manual?
Thanks.
On the wes50 at least the pencil like magnet is used to set and lock
the maximum temperature setting of the iron. It has nothing to do with
esd, must be a magnetically sensitive device back behind that area.
I cant find the manual or the magnet stick for my weller.
Weller will probably send a manual if you write or email them and
request one.
connect to what.
Thanks, John. This is just the kind of help I was hoping for
request one.
Great - thanks for your help. Maybe I'm just locked @ 0
degrees.
