What can I make with the programmable electronics from my wife's oldcoffee pot?
My wife's old coffee pot bit the dust mechanically, and has been replaced. I have the programmable electronic clock and controls which still work perfectly. The programmble control allows turning on of any load up to about 15 amps, based on the relay that does the switching of the 120V to the load.. Once on, I believe the load is connected permanently. I haven't tested that yet.
Now I am wondering what to do with the electronics. I hate to just toss out a perfectly functioning clock and timer. IDEAS!!!!!????!!!!!
Why do I envision the episode of The Simpsons in which Homer makes a time machine out of a toaster ?
Anyway, many years ago I had a digital clock with a timer that instead of having a radio, had an outlet on the side. I have no idea what happened to it but I lost it somehow. I know I lost it because I wouldn't have given it away or sold it. I thought it a useful thing.
I think it used to turn off after a couple of hours, pretty much like a clock radio does. You'll probably find the same about this. After a while theywouldn't want the heating element on all day. I would think......
The brewing element is what pulled all the current though, and it wasn't a big concern because when it's not suberged in water it turns on for a splitsecond then the thermostat turns it off for quite some time.
To be the most versatile I think the best idea would be to just wire an electrcal outlet to it.
My wife's old coffee pot bit the dust mechanically, and has been replaced.. I have the programmable electronic clock and controls which still work perfectly. The programmble control allows turning on of any load up to about 15 amps, based on the relay that does the switching of the 120V to the load.. Once on, I believe the load is connected permanently. I haven't tested that yet. Now I am wondering what to do with the electronics. I hate to just toss out a perfectly functioning clock and timer. IDEAS!!!!!????!!!!!
See my comments on alt.home.repair
K
Kalyan Ram
://www.web-design-hyderabad.in/seo-course-in-neredmet/
Contact for advisor : +91 9177522892
Web Design Hyderabad has a great demand and much more competition, But manyof companies are not able to provide good service for customers, The problem might be because of design quality, not providing dynamic works like contact form or may be client expecting more work with very low cost.
To work with Web Design in Hyderabad, A designer should more honest with the client, you have to be explain the work of cost exactly, If not a designer will be struggled one day with client, Every one knows a designer can doany work but it takes time right, We have to cost as per our time
web design companies in hyderabad
Web design history
The Hypertext concept was invented by Ted Nelson in 60s, however it was used only for some decades after. During 1992 to 1994 other developers startedadding up their own bits of HTML codes. HTML 1 tags and the HTML 2 born. As internet faster now the Web designers are putting more HTML capabilities.In 1995 more HTML tags have appeared and HTMl 3 was born. Now designers have an lot of option to use HTML B tables and style sheets and many more. They also have animated images, and Flash also introduced. It changed the whole landscape of web design from static to dynamic.
The first web site published in the World Wide Web history at sometime in August of 1981. It was some 30 years ago, however the Internet born in the sixties. It wasn’t fast as today. However it was capable in transferring information from one computer to another. Tim Berners was the first person who invented the World Wide Web. Tim Berners is British computer scientist. The First website launched in year 1990. on December 25 1990 with the help of Robert Cailliau and young student at CERN, Tim Berners implemented firstsuccessful communication between a Hypertext Transfer Protocol (HTTP) patron and server via Internet.
Cydrome Leader
Jeff Liebermann said:
Find a suitable package and turn it into a digital clock.
I used an oven clock as just a clock for years. It had a huge bright
flourescent display.
Michael Black
I've long used a Delco digitally tuned car radio as a bedside radio. I
think the display is flourescent, it's not LED or LCD. I soon discovered
I needed to find how to dim the display, with the lights off the radio
display almost lit up the room.
Michael
Cydrome Leader
A car radio next to the bed is a great idea.
