What Does Your Electronics Workshop Look Like?
Too_Many_Tools
With the holiday season here it is time to redo the workshop and the
workbench in particular.
So, what suggestions do you have for setting up a good efficient
workspace for electronics?
Here's an example that I found....
http://www.stevenjohnson.com/workbench.htm
So what does your workspace, test bench and layout look like?
Pictures and links would be great.
What has worked for you?...what hasn't?
Benches, racks, cabinets, tables, carts....
Any particular test equipment that you would recommend for or against?
TMT
Mark D. Zacharias
TMT
Well, it's certainly cleaner and neater than MY bench!
Mark Z.
Dale Parfitt
TMT
Here's a couple pix of my shop. For test equipment- stick with the knowns-
HP/Agielnt, Tektronix etc.
http://www.w4dex.com/gallery/Dale-Parfitt/Dale_Parfitt_W4OP
http://www.w4dex.com/gallery/Dale-Parfitt/Dale_Parfitt_W4OP_3
W4OP
Tim Wescott
TMT
My workbench looks like an absolute fright unless I've been very
unproductive (and therefore have had time to clean), or I've reached a
standstill (and therefore must clean).
Otherwise I just look at the pile and ask myself how long ago I used a
particular tool, then I look that far down to find it.
I like the pictures of the shop..really neat and clean..I have worked
in radio for about 60 years and you get sort of "set in your ways"..
I like to work on a roll around cart about 24 X 30 in. 28 in.
heigh.That way you can have test equip and tools within reach..I have
all the digital test sets and I always have an analog meter,like
Simpson 260 and Tripplet.630 ...Also I have a complete soldering
station with everything modern,,but I always have a gun or two on the
bench also..For boatanchors you really need some analog stuff,like HV
multimeter to 6000 volts etc..A maglight is a must for close in
work..A good assortment of power supplies,from 0 to 50 volts regulated
and a good 12 volt PS at about 30 amps.or more..A good scope to at
least 50 Mhz,preferabily 100/200 mhz.If you get a Tektronics scope you
can attach a didital counter to the scope (ch.1 out)and read frequency
as well as pattern.Helps when working on freq .multipliers etc..Just
some ideas and suggestions..Good military Test equip. is available for
pennies . repairing it ,not always easy..Good luck W4PQW
I
Irv Finkleman
TMT
If I ever manage to get to the point where I can find the bench
underneath the clutter I will be more than happy to send you a photo
of it. I should have taken one when it was new for sentimental
reasons! :)
Irv VE6BP
P.S. If you think the bench is bad, you should see the shack!
Michael A. Terrell
reasons! :)
Irv VE6BP
has a contest from time to time with
pictures of workbenches and home shops. Its about time for someone to
post another "My bench" photo and start another round over there.
Arfa Daily
Tim Wescott
Wescott Design Services
http://www.wescottdesign.com
Oh deep joy !!! That is a perfect description of my workshop. I wish I
could keep it looking like the pictures in the post above. I have as much
benchspace, but on an average day, probably about 18" to 2 foot available
On another similar sized bench behind me, I have one of the workshop
computers, the weather sat receiving equipment, and my amateur radio
station. On that bench, on a good day, there's just about room for the
station logbook !
Arfa
Jeff L
Spehro Pefhany said:
Nice and neat. What are those cool vertical outlet boxes-- a
commercial product?
Those look like part of the bench - I know some of the brands of benches
available used to have the plugs there. My benches have a 6' strip with
plugs every 3 - 4" that we bought from I believe Tripp Lite last summer.
They were quite reasonable with a lighted, covered switch, circuit breaker,
a 10 to 15' long heavy grounded cord, with a nice extruded aluminum housing
for ~$70 CND @ something like 7 qty. They make many styles and lengths.
Jeff
What kind of a critter lives in that bed beside the Tek scope?
Best regards,
Spehro Pefhany
http://www.speff.com
Jason D.
Size of stuff to fix upon determines the design of bench and tools.
I'm TV tech;
Big ones like 36'ers demands at least 5 feet by 10 even more feet
bench to allow for tools to lay besides the unit. I have wished I had
that because of few CTC210/DTV306/etc that needed the depth so I can
push the unit way forward so I can eagle spread the crowded chassis
that weighs a tonne and clumsy to handle just to freaking replace 10
parts in worst places. Lot of chassis flipping just to see as you put
new parts in and remove and resolder transformer for that R14609 tiny
10 ohm resistor that's now a black crater, that D14611 did to
components in standby SMPS.
Be make sure the bench is high enough so you don't bend over so low
but not too high to heft heavy TV up there. Flat CRTs are heavy!
Cheers, Wizard
John Miles
The TekScopes group on Yahoo did this awhile back, too. Lots of fun to
look at other scope junkies' benches.
http://www.frappr.com/tekscopes
-- jm
I dont do much tronic work now, but just did some today. A lot of the
things I found are just as true in what I do now though.
The no. 1 handy thing is a little hand held probe that amplifies and
send the signal to a piezo. Its an imprecise but very quick way of
finding out roughly whats going on here there and almost everywhere.
The one thing I avoided like the plague, and still do, is those plastic
drawer racks with often open top drawer boxes. You've only got to move
one once to see what I mean! One spill and you'll never ever buy one
again. Small parts containers must have burst proof latches, I wont use
any that dont.
Domestic chipboard chests of drawers are a good quick cheap way to get
storage space in situations where you can be sure nothing will be put
in front of them. Especially good where your storage expands into
living space. They sometimes need reinforcing, ie more runner screws
and gluing draw bottoms in. Yes its ok to do that with chipboard
drawers (not with real wood ones tho).
Wooden shelving has the advantage that its easily made in any size,
weight and shape to suit your workshop. And with any features you want
on it. If you want large quantity or heavyweight, its also less money
than large amounts of steel. A lot slower to put up, but much more
adaptable. Shelving racks of all kinds can have overhead linking bars
betwen them to make them rock steady. Realise a shelving rack collapse
can kill, they must be rock steady.
If you can take a photo of your workshop, youre failing to use a lot of
the space.
Cardboard boxes have always been my favoured storage cases, as they
offer some amount of protection in case one is dropped, and theyre
freely available at any time, which is also important. And any size. As
I've found, always label them!
For the ultimate in space efficient storage theres always tracked
shelving racks, but theyre not cheap. Metal racks on tracked wheels,
with a big knob/lever that you turn to move them. One only need
maintain one gangway between the lot, move them to enable to get to
where you want. Very effective if youre storing on a larger scale, and
space is expensive, as it is here (very). A serious space saver, but
access is slower. Fill them in order of whats most used to minimise
moving.
Soldering guns I've found almost useless. Theyre not good performers,
and how many jobs are done so fast there isnt time to do something else
while an iron heats up? Havent used mine in so long I dont even know
where it is.
Gas lighting has proven more reliable for power cuts than battery,
though these days battery exit lights are now common.
NT
Michael A. Terrell
any that dont.
I moved over 1000 miles in 1987 and I had 24 50 drawer Akro-Mills
cabinets full of parts. I cut pieces of cardboard to cover the front and
placed two of them face to face, then taped them together. I didn't
have even one part out of place when I arrived at my new place and set
up my shop. The move was done with my shop's step van and I hauled over
17,000 pounds of tools, parts, manuals and test equipment in two trips.
there is nothing wrong with parts cabinets, if you know how to pack
them.
COLIN LAMB
The last time my bench was clean was over a decade ago - after I learned I
had a very aggressive form of cancer. I reluctantly cleaned off the bench
to save my wife from having to do it.
But, through the miracles of drugs, the cancer went away. Now, my desks are
all cluttered again. My wife fondly talks about how good life was when my
desk was clean and I had sold much of my junk. I think she is kidding, but
would not bet my life on it.
When I clean an area, it is only temporary.
At the constant prodding of my wife, I spend 3 months cleaning up the floor
of my darkroom. I found things that had been missing for years. But, I
could not clean up the desk, for it has all the little parts for which I do
not have a place for.
In the end, messiness is really just the product of someone who has so much
order that he insists upon a place for each item before he puts it away.
Colin K7FM
Mr Fed UP
Gee Whizz this 36 inch I have weighs in at 200 pounds.
Maybe you need to think about a motor hoist with straps or something.
I know by myself this TV will never be moved. Maybe it can sell
with the house some day. Good luck with the hernias.
I have a 12 X 24 patio I am thinking of enclosing and making a shop...
so I am following this thread too. lol where ever it goes
K4TWO Gary
Michael A. Terrell
Colin K7FM
A workbench is meant to be a living example of the moving hole
theory. ;-)
Don Foreman
Bench: I made my 14' bench of 3/4" MDF on top of 3/4" plywood. I
made cantilever L supports welded up from 1" x 2" x 1/8" steel
rectangular tubing so there would be no legs to get in the way. The
supports are lagbolted to studs in the wall. This has proven to be a
very sturdy bench, and the MDF is a nice worksurface. I gave it two
coats of satin varnish so it'd resist coffee spills, etc. My
skeptical neighbor climbed up on the cantilevered bench-with-no-legs
and jumped up and down a few times, then pronounced it good. I
designed it for 1500 lb per support so I think I could set an engine
block on it with no worry, much less surfacemount parts.
Other stuff:
A really good lab stool with casters, a foot ring, gas spring and a
lever-actuated gas spring height adjuster is a godsend.
An Ott tru-color light (as found at Jo-Ann Fabrics) makes reading
resistor color codes a lot easier. Wait for sales or sign up for sale
coupons in the mail so you can get it at half price.
For surfacemount work, a binocular zoom microscope. I got mine on
EBay, after several tries. I really like my Pace TW-100 soldering
station though I'm sure there are others that are just as good or
better.
A good vise for working on circuitboard that can grip the board by the
edges and can flip and tilt. I couldn't find anything I liked so I
made mine.
http://users.goldengate.net/~dforeman/cctvise/
I can slide this vise under my microscope for surfacemount work. The
variable-height labstool is particularly useful when working with the
scope.
Several small Palmgren drillpress vises to hold small things while
working on them as perhaps when sticking Luxeon emitters to heatsink
slugs, and then soldering leads to them.
