What S/W will simulate a transmission line type pulse transformer?
I tried simulating a transmission line transformer (one end connected
in parallel, the other end in series) using "CircuitMaker 2000" and
"MultiSim 8", but apparently the models these programs use (even the
lossy line model) are not appropriate for this type of simulation.
I'm wondering, does anyone know of software that will realistically
simulate such transmission line based circuits in the time domain?
Thank you.
John Popelish
Thank you.
I have been working up a spice model of a transmission line
transformer that approximates it with 16 inductances and 17
capacitances. It was meant to model a transformer wound through two
flat cable cores, so that the winding pair runs straight down the
slots, with the ends as far as possible from each other. It includes
the 120 mutual inductance coupling factors that model the reduction of
coupling efficiency as turns get further apart and both the normal
transmission line capacitance per length and the capacitance between 1
turn and the next of the pair. The responses have not been tested
against actual measurements, but they look quite reasonable, as long
as the phase shift per inductance segment is a small part of a cycle.
I selected the inductance and capacitance values to fit test data on a
particular example, but you can change them.
I built it for LTspice, free download at:
http://www.linear.com/company/software.jsp
If you would like to have a copy of this component model and its
symbol file, email me.
John Larkin
A long string of L's and C's makes a good transmission line model, but
the number of sections explodes as a power of the delay/risetime
ratio. I've done lines with hundreds of sections.
Most Spice transmission line models contain a hidden isolation
transformer (you can apply DC between the 'shields' of opposite ends)
and aren't very realistic for things like transmission-line
transformers.
John
Mike Engelhardt
John,
isolation transformer (you can apply DC between the
'shields' of opposite ends) and aren't very realistic
for things like transmission-line transformers.
In SPICE-speak, the transmission line device of SPICE
handles a single node. A length of coax has two nodes,
normal mode and common mode. To invert, you need to
model both modes. The classic example is in Larry
Nagel's PhD thesis(Berkeley 1975), but here's a
deck that will show how to do a transmission line
inverter in LTspice on the netlist level:
* transmission line inverter
T2 0 0 OUT 0 Td=50n Z0=75 ; center conductor
T1 IN 0 0 OUT Td=70n Z0=50 ; shield higher Z but faster
V1 IN 0 PULSE(0 1 0 1n 1n 10n) Rser=50
..tran 0 500n 0 1n
..end
The general case is that a cable has as many modes
as conductors including the shield. That the SPICE
transmission line device supplies only a single node
is an odd concept to be sure -- a cable with but a
single wire but controlled impedance. Just the same,
it's supper useful if you ground each end of one of
the sides. Then you can simulate the normal mode and
skip the common mode if it doesn't interest you.
--Mike
John Larkin
John,
model both modes.
This is a super-wideband inverter, in both Spice and real life:
in+ ----( coax )----(---------------)
in- ----(----------------)----( coax )------ out+
(---------------)------ out-
The Spice version is perfect. The real version has problems if IN- and
OUT- are both grounded (the whole thing becomes a short) and that
limits low-frequency response. Slipping a ferrite over it somewhere
helps the lf end a lot. The center crossover should be zero-length.
Done with a couple of hunks of hardline, it's very impressive.
John
Mike Engelhardt
John,
life:
if IN- and OUT- are both grounded (the whole thing becomes a
short) and that limits low-frequency response. Slipping a
ferrite over it somewhere helps the lf end a lot. The center
crossover should be zero-length. Done with a couple of hunks
Interesting example. Thanks.
But it doesn't work very in SPICE if you dutifully model both
modes of each cable. Your circuit above requires four SPICE
transmission line elements. Yes, if you ignore two
propagation modes, it's perfect in SPICE but that is an
error in the application of SPICE. Below is an LTspice
schematic that illustrates perfect behavior from incorrect
analysis and the results from using 4 ideal propagation modes.
Regards,
--Mike
--- xmissionbs.asc ---
Version 4
SHEET 1 880 680
WIRE -240 208 -240 -96
WIRE -240 272 -240 208
WIRE -240 400 -240 352
WIRE -160 -96 -240 -96
WIRE -160 208 -240 208
WIRE 16 -16 -80 -16
WIRE 16 -16 16 -64
WIRE 16 16 16 -16
WIRE 16 96 16 48
WIRE 48 272 -48 272
WIRE 48 272 48 240
WIRE 48 288 48 272
WIRE 64 -96 -80 -96
WIRE 64 -64 16 -64
WIRE 64 16 16 16
WIRE 64 48 16 48
WIRE 96 208 -80 208
WIRE 96 240 48 240
WIRE 208 -64 160 -64
WIRE 208 -16 208 -64
WIRE 208 16 160 16
WIRE 208 16 208 -16
WIRE 208 48 160 48
WIRE 208 96 208 48
WIRE 240 -96 160 -96
WIRE 240 -16 208 -16
WIRE 240 240 192 240
WIRE 240 288 240 240
WIRE 256 208 192 208
WIRE 256 240 240 240
WIRE 288 208 256 240
WIRE 288 240 256 208
WIRE 304 -96 240 -16
WIRE 304 -16 240 -96
WIRE 336 -16 304 -16
WIRE 336 -16 336 -64
WIRE 336 16 336 -16
WIRE 336 96 336 48
WIRE 352 208 288 208
WIRE 352 240 288 240
WIRE 384 -96 304 -96
WIRE 384 -64 336 -64
WIRE 384 16 336 16
WIRE 384 48 336 48
WIRE 496 240 448 240
WIRE 496 288 496 240
WIRE 528 -64 480 -64
WIRE 528 -16 528 -64
WIRE 528 16 480 16
WIRE 528 16 528 -16
WIRE 528 48 480 48
WIRE 528 96 528 48
WIRE 560 208 448 208
WIRE 576 288 496 288
WIRE 608 -96 480 -96
WIRE 768 -16 528 -16
FLAG 48 288 0
FLAG 240 288 0
FLAG -240 400 0
FLAG -48 272 0
FLAG 560 208 0
FLAG 16 96 0
FLAG 208 96 0
FLAG -80 -16 0
FLAG 336 96 0
FLAG 528 96 0
FLAG 608 -96 0
SYMBOL tline 144 224 R0
WINDOW 3 -76 43 Left 0
SYMATTR Value Td=70n Z0=50
SYMATTR InstName T1
SYMBOL voltage -240 256 R0
WINDOW 123 0 0 Left 0
WINDOW 39 24 132 Left 0
SYMATTR InstName V1
SYMATTR Value PULSE(0 1 0 1n 1n 10n)
SYMBOL tline 400 224 R0
SYMATTR InstName T3
SYMBOL tline 112 -80 R0
SYMATTR InstName T2
SYMBOL tline 112 32 R0
SYMATTR Value Td=50n Z0=75
SYMATTR InstName T4
SYMBOL tline 432 -80 R0
SYMATTR InstName T5
SYMBOL tline 432 32 R0
SYMATTR InstName T6
SYMBOL res -64 192 R90
WINDOW 0 0 56 VBottom 0
WINDOW 3 32 56 VTop 0
SYMATTR InstName R1
SYMATTR Value 50
SYMBOL res -64 -112 R90
SYMATTR InstName R2
SYMATTR Value 50
TEXT 288 352 Left 0 !.tran 0 500n 0 1n
TEXT -16 208 Bottom 0 ;IN+
TEXT -16 272 Bottom 0 ;IN-
TEXT 528 208 Bottom 0 ;OUT-
TEXT 536 288 Bottom 0 ;OUT+
TEXT -48 -96 Bottom 0 ;IN+
TEXT -48 -16 Bottom 0 ;IN-
TEXT 560 -96 Bottom 0 ;OUT-
TEXT 568 -16 Bottom 0 ;OUT+
TEXT 272 -104 Bottom 0 ;"Correct"
TEXT 272 176 Bottom 0 ;"Incorrect"
