What's inside an analog 4-quadrant multiplier?
Tim Shoppa
The data sheets for analog 4-quadrant multiplier-on-a-chip chips are
remarkably vague as to what goes on inside the chip. I'm thinking
specifically of the Anaalog Devices AD633 and the Burr-Brown MPY634,
which are (at my level of viewing) similar in overall function and
specs (but different in some details.)
Some thoughts:
1. One-quadrant multiplying doesn't seem too hard. Take the logs, add
the logs, exponentiate the log. Basic building blocks are things I
think I understand pretty well.
2. Four-quadrant multiplying is still somewhat a mystery. The AD633
just says it has a "translinear core". I have about as much
understanding of that as if they had said "dilithium crystals". The
MPY634 data sheet doesn't even say that much, it just jumps right into
an equation without relating it to any internal functions.
3. Maybe a four-quadrant multiplier can be done with a one-quadrant
multiplier, some absolute-value-taking circuits, and some comparators,
and a final multiply-by x1 or x-1 depending on the comparators.
4. One clue that the MPY634 and AD633 don't use the method I suggest
in (3) is a lack of symmetry in the X and Y inputs. One input always
has a linearity of maybe 4 times better linearity than the other. This
indicates to me that internally there is some assymetry that isn't
necessarily implied by my simple suggestion.
5. Maybe the "translinear core" is something like a Gilbert cell. Or
is it just a clever application of the Barrie patent that describes how
things like the AD603 work? (See my thread here from September about
how the AD603 works.) Even then that only gets you two quadrants...
but there is an assymetry in the input such that maybe some other trick
comes in.
So how many of my 5 thoughts above are completely and hopelessly wrong?
All 5? :)
If there's some Barrie patent that explains all this, I'd love to read
it. When I've been pointed directly towards them in the past, they were
always a joy to read. But I've got an exceptionally thick head and
unless I'm pointed towards a specific one my eyes still glaze over in
the claims section :-(
Tim.
Jim Thompson
Some thoughts:
comes in.
All 5? :)
Tim.
Look back thru my MC1494/95/96 threads. Particularly the
linearization of the multiplier core.
...Jim Thompson
John Larkin
Some thoughts:
comes in.
All 5? :)
Tim.
Bunch of Gilbert cells, usually.
This has a schematic...
http://www.onsemi.com/pub/Collateral/MC1494-D.PDF
John
John Larkin
...Jim Thompson
Did you do the 1494?
John
Tim Shoppa
Yeah, I know how to use a Gilbert cell to make a 2-quadrant multiplier.
But how do they use them to make a 4-quadrant multiplier? My method
would be compare-with-zeroes and absolute value circuits and a final
stage of multiply by +1 or -1, but I don't think this is the "clever"
way.
Hmm, I see the Gilbert cells in the multiplier section, but as for the
theory they just refer to AN489, which is nowhere to be found. Can
someone either explain to me (keeping in mind how slow and stupid I am)
how 4-quadrant multiplication works, or point me to an online copy of
AN489?
Tim.
Tim Shoppa
I appreciate the cleverness of the linearization, but even then the
MC1494 requires 4 external pots to finish the linearization and set the
scale voltage.
I'm sure that the MPY634 and AD633 use laser-trimmed resistors
internally to remove the need for all these pots just for external
trimming. And they may have other tricks up their sleeves (especially
AD, not so sure about Burr-Brown!) to make things even slicker.
But I still do not understand how to turn a Gilbert cell (a 2-quadrant
multiplier) into a 4-quadrant multiplier. Maybe it's just a mental
block, maybe it's just my fundamental stupidity. Can someone enlighten
me?
Tim.
John Larkin
scale voltage.
me?
Tim.
You use two. Differential X base inputs are paralleled, diff collector
outputs are paralleled, and you drive the bottom current sources out
of phase from the Y signal. Something like that.
John
Tim Stinchcombe
Tim,
This may give you the enlightenment you need:
http://www.onsemi.com/pub/Collateral/AN531-D.PDF
The algebra in the appendix isn't as elegant as it could be, but from
memory, there is nothing fundamentally wrong with it, it's just a little
clumsy. It also looks very similar to that in AN-489, but I haven't checked
that it is literally the same. (To get AN-489, Motorola or OnSemi - can't
remember which - had to fax it to me, so I doubt you'll find it on the web).
Tim
(neither of the 2 ways I access s.e.d shows me the full thread, so apologies
if this is slightly out of place...)
Tim Shoppa
Ah, thank you. Now that I see that, I can begin to appreciate some of
the finer points of linearization that Jim has talked about here in the
past. It's now obvious why the X input has different linearity specs
than the Y input. It's also now obvious to me why most MC1496 designs
use transformer coupling :).
If anyone wants to chime in with how Analog Devices and Burr-Brown
mass-produce devices with no external trimmers, I'll gladly listen, but
for now my curiosity is mostly satisfied. Maybe I'll try to build some
multipliers out of CA3046's or MC1496's and see how they perform and
appreciate the matching/linearization in the MPY634 and AD633.
Stupid Google Groups, and my fault for using it. I gotta get my trn
working again. The good thing is that Google Groups is so frustrating
that I now spend more time in the real world and less wasted time
reading newsgroups...
Tim.
Stephan Goldstein
<snip remainder>
I'll see if I can find some publicly disclosable information about this next
week when I return to work (we're shut this week).
Steve
ADI employee by day...
John Nagle
specifically of the Analog Devices AD633 and the Burr-Brown MPY634,
There's a classic approach from the analog computer world,
the "quarter square" multiplier. This is symmetrical in X and Y.
Recall that
A*B = ((A+B)^2 - (A-B)^2) / 4
Op-amps can do sum and difference. Logarithmic
amps can do squaring. So this is quite buildable.
This approach goes back to the tube era. NEC
revived it in 1994. It's not seen often any more, but
if you want a instrument-grade analog multiplier,
it's the way to go.
http://ieeexplore.ieee.org/xpl/abs_free.jsp?arNumber=272093
John Nagle
John Larkin
Recall that
it's the way to go.
John Nagle
The real precision multipliers are duty-cycle modulators. But slow.
Or, um, motor-driven pots.
John
gwhite
The '96 doesn't have the linearization of the core... does it?
It is simpler and is the only one of the series available anymore, as far as I
know.
Robert Baer
Recall that
it's the way to go.
John Nagle
Another way the log function was done was witha Diode Function
generator (DFG).
Using the analog computer, one can set-up a sweep of the error (sweep
one input, plot against error) and see a "sawtooth" ripple on top of the
"slow" errors which usually look like a 2nd or 3rd order error curve
from end to end.
At least with the dynamic display, it was easier and faster to adjust
for minimum overall errors.
The textbook method used constants and sucked in over all useability
results.
Robert Baer
John
Motor driven MaryJane? To get away from the Feds?
N
Nicholas O. Lindan
If you can, I would advise doing the math in software. Log amps are
a continual sore spot in the equipment that uses them.
John Nagle
Robert said:
Old analog computers used servomotors driving potentiometers
for slow multiplication. Slow, but good accuracy.
There are mixing consoles today which do this.
Photoresistive photocells can also be used as
multipliers.
John Nagle
Max
are remarkably vague as to what goes on inside...
I'm thinking specifically of the Anaalog Devices
AD633 and the Burr-Brown MPY634 ...
I don't know those specific chips offhand. However in answer to the
core question, there was some in-depth exchange on
sci.electronics.design recently about "translinear" circuits (under a
"Square-root" subject) in which I cited the seminal papers by Gilbert
that popularized the standard BJT four-quadrant multiplication
technique. (By the way, I worked under Barrie Gilbert, some time ago.)
A bit of patient searching and reading under "translinear" -- with
some patience for the lame after-the-fact cobbled-together explanations
that tend to be numerous on Web sites -- should reveal much.
(It has little to do with "log-antilog," except implicitly.)
Now a trivia question for the analog hotshots here, the real hot shots,
about analog multiplication. Not serving Tim Shoppa's question, but of
historical interest. (Later I'll post answer and classic references.)
I assume this wasn't covered recently; if it was, never mind. The
question concerns basic _mathematical_ identities that can (by various
practical means) be harnessed to build a multiplication out of other
kinds of mathematical operations. There are _three_ classic ones.
Everybody (who is an analog hotshot anyway, or reads textbooks) knows
_two_ of them: the log-antilog identity, and the quarter-square
identity (given recently in this thread). What is the third?
Cheers -- Max
