What's the total resistance of this network?
Dave Farrance
I'm designing a circuit and found myself unable to figure out the
resistor values. How embarrassing. After trying to break down the
problem using equivalent circuits, I found that the problem in its most
basic form is that I can't figure out the total resistance of this:
(fixed pitch needed to display this, of course)
| d |
a | b c |
o----+----/\/\/\/----+----/\/\/\/----+----/\/\/\/----+----o
| e |
Anybody know? Or maybe somebody could point me to a web resource with
tips on how to get to grips with a tangled network like this?
John F
most basic form is that I can't figure out the total resistance of
this:
| d |
a | b c |
| e |
with
Easy :) Rearrange it a bit:
o-----------o
/e /a
| b |
/c /d
o-----------o
Now calculate :)
Hint: use Thevenin's theoreme to get the voltage across :)
Dave Farrance
Thanks for the suggestion, but I dunno. It seems to me that Thevenin's
theorem only works where you can avoid that construct. The interaction
between the resistances is still overtaxing my brain.
v1 o-----------o v1
/e /a
| b |
v2 +--/\/\/\/--+ v3
/c /d
0v o-----------o 0v
Now calculate :)
I think that you're suggesting that I add voltages as above, work out
the equations at each node, and substitute for the voltages until
they're eliminated. It doesn't look solvable to me I'm afraid:
(v1-v2)/e = (v2-v3)/b + v2/c
(v1-v3)/a + (v2-v3)/b = v3/d
Genome
| d |
a | b c |
| e |
I usually find that not designing in silly resistor networks helps a lot in
that you don't have to solve them.
I suppose it's a matter of preference but, if you try my method, I can
assure you that it's much easier.
DNA
DNA
Dave Farrance
Yes, yes, surely I could rearrange the design so that it didn't have
tangles like that. I know. Trouble is, I've got to fit in with a
previous design and with cost constraints, and it's hard to avoid.
Genome
There's always some damn excuse isn't there :)
DNA
Jon
| d |
a | b c |
| e |
Thevenin eqiuvalent resistance = (open ckt voltage)/Short Circuit
Current.
| d |
a | b c |
| e | |
Vin ----------/\/\/\/------------- |
o
Write 3 voltage loops, e.g.,
a, b, e (I1)
b, d, c (I2)
e, c, Ground (I3)
Solve for I3
Open circuit voltage = Vin
Req = Vin/I3
Jim Thompson
| d |
a | b c |
| e |
It's called loop and nodal analysis.
...Jim Thompson
John F
Thevenin's
interaction
v1 o-----------o v1
/e /a
| b |
v2 +--/\/\/\/--+ v3
/c /d
0v o-----------o 0v
Now calculate :)
out
Similar... Transform into
v1 o---- ---o v1
/e /a
| b |
v2 +--/\/\/\/--+ v3
/c /d
0v o---- ---o 0v
and now you are able to do thevenin twice:
e||c v2 b v3 a||d
v1*c/(e+c)----/\/\/\/----/\/\/\/-----/\/\/\/----v1*d/(a+d)
now you can easily calculate v2 and v3 as a function of v1.
then the current across b ...
Another idea... use superposition of
1) left v1 and
2) right v1
SO many possibilities.
K
krw
Thevanize e, c, and v1, and a, d, v1. Then use superposition to
combine those with b. Stir and serve cold.
Dave Farrance
Current.
| d |
a | b c |
| e | |
o
a, b, e (I1)
b, d, c (I2)
e, c, Ground (I3)
Solve for I3
Req = Vin/I3
Thanks Jon and Jim Thompson for pointing out loop analysis.
This web page gives a technique which I finds works OK if I put in
actual numbers for the resistor values and I can then get a numerical
answer after a non-trivial effort.
http://mathonweb.com/help/backgd4.htm
If I try to retain the algebraic form while using this technique,
though, it quickly turns into a monster. Hmm. I'll have to think if I
can simplify the original form of the puzzle a bit.
John Larkin
| d |
a | b c |
| e |
Hell, Spice it!
John
Greg Neill
John Larkin said:
Hell, Spice it!
Well, that's certainly one way to do it.
If I had to analyze this circuit, I think I'd start
by performing a Delta-Y transformation for resistors
a,b,e. Should be clear sailing from there.
Dave Farrance
Aha. Thanks. Problem solved.
| d |
| ab c |
o----- \ ----- -----/\/\/\/----+----o
| / a+b+e |
| ae / be |
| a+b+e | a+b+e |
John Popelish
A few months ago, someone posted the formula for total
resistance of this arrangement, but I can't find it through
Google.
The Thevenin's equivalent solution is shown here:
http://www.broadcast.net/hallikainen/theory6.html
The Phantom
| d |
a | b c |
| e |
Just say "Om mane padme hum", and stare at it for a while. Say to
yourself, "if it weren't for that pesky b resistor, the total resistance
would be the parallel combination of the two arms; something like:"
(a+d)(c+e)
a+c+d+e
Just a plain product over the sum.
Ah, yes. Now I see it. It's:
a(de + b(c+e) + c(d+e)) + d(ce + b(c+e)
a(b+c+d) + b(c+d+e) + e(c+d)
I know you're looking for a solution method which I haven't given. :)
But I see in another post that you have been tipped off to the delta-Y
transformation. This result provided for checking purposes only.
Robert Baer
| d |
a | b c |
| e |
Here is a rare case when delta-to-wye conversion is useful; take the
3 points described by b, c, and d (note the delta configuration, and
convert it to a wye resistor configuration B, C, and D (same points; now
have an extra point in "middle".
The derivation of that conversion is fairly simple but i have never
seen it mentioned in any university of note (over the past 50 years).
Once you have the wye values, the reduction is simple.
BTW, this is the classical bridge, so if there is any symmetry, even
on a ratio basis, take advantage.
There are at least 4 different ways to solve the "resistor cube"
problem (what is the resistance across the farmost corners, given all
sides are of one ohm resistors); many "cheat" based on the symmetry.
Robert Baer
DNA
DNA
I prefer funny resistor networks, as the silly ones keeps the clowns
agitated.
F
Fred Bloggs
It's one thing to come up with a tangled formula and entirely something
else to make sense of it:
View in a fixed-width font such as Courier.
K
kell
| d |
a | b c |
| e |
Here's a closely related problem:
http://groups.google.com/group/sci....894955a1365?lnk=st&q=&rnum=2#1ae15894955a1365
