Where can I find a 60pin 1.27mm connector???
Edu
Hello.
I have just bought a GSM oem module, and am having lots of trouble to
find the connector for this module.
It should be a 60 pin (in 2x30), for flat cable, like the ones in IDE
drives, but with a spacing (both between pins and rows) of 1.27mm
(0.05") , instead of 2.54mm (0.1 ").
For the moment I have not had any luck. At first I will need only 2
connectors to develop my prototype, but surely in short I will be
buying lots.
Any help?
Thanks!
Edu
Robert Baer
Edu said:
Hello.
buying lots.
Any help?
Thanks!
Edu
See DigiKey pages 61-62, 67-70, 86, 166-170, 329 (verified, as
sometimes listing in product index is incorrect).
Am sure Mouser also carries same lines.
Edu
Thanks for all those references, but I haven't found what I need in
them.
Is there any way I can query someone in digikey with my description of
the product?
What does people who buy a Sony-Ericsson GSM GR47 module do with the
connector??? Where do they get it???
Thanks!
Edu
Robert Baer ha escrito:
Donald
them.
the product?
Thanks!
Edu
You are making your search too complicated.
Looking at the pictures of the module at:
http://www.sonyericsson.com/spg.jsp?cc=us&lc=en&ver=4002&template=pp1_1&zone=pp&lm=pp1&pid=10086
Its just a dual-row connector.
Looking at other products that use this module shows just a dual-row
connector.
http://www.google.com/search?hl=en&lr=&c2coff=1&q=Sony-Ericsson+GSM+GR47+connector
Good Luck
donald
linnix
them.
the product?
connector???
You put the male connector on a Flexible Circuit board.
It comes in 80 pins right angle surface mounted dual row 0.05" pitch.
I got a few pins sample left (4 pins). Minimum order is 1,000 @ 50
cents each.
