Where to get Fluke spares..surge protectors.
To complete repairs of a Fluke 23 I now only require some "1500 V
surge protectors". That's what the BOM on the Fluke 70 series service
manual calls them. Though on the 23 model one of them is actually 2 in
series.
These are red, about 5mm dia x 4mm. markings are
H NI
1399
They look like old Harris or GE MOV's.
The other one is yellow, 8x8x5mm, has a sawn slit half way through it
and has markings
MDC
1-2KV
9143
Any clues where to get similar ones at least? Farnell, Digikey and RS
don't appear to go that high in voltage choices.
Phil Allison
<[email protected]
series.
** Then MOVs are what the probably are.
Farnell have 7mm MOVs in 460 Vrms or 750 VDC @ 1mA - so two of them
gives you 1500 VDC.
Cat: 100-4346 for $1.21+
** Then that is no MOV - it is a spark gap.
Not likely to need replacement - just a clean.
...... Phil
<[email protected]
gives you 1500 VDC.
That looks like the nearest thing around. I'll grab some.
OK.. so I had a close look inside the gap and spied a tiny bit of grit
there. Cleaned with some shim, now the resistance shows megohm instead
of ohms. I will get a new one, but replace for now.
Phil Allison
<[email protected]
"Phil Allison"
** Very hard to find anyone selling such spark gaps.
Might be easier to extract one from the neck PCB of an old CRT monitor -
look out for one in the nature strip fodder.
..... Phil
Mik DaDik
You might find some in old `junk box' PC power supplies...
Cu
F
Franc Zabkar
series.
H NI
1399
and has markings
MDC
Fluke's supplier code for that part is 91984.
This URL suggests that "MDC" is "MAIDA DEVELOPMENT CO":
http://www.tpub.com/content/logistics/59/10/759/01-319-9890.htm
This is MDC's web site:
http://www.maida.com/content/products/products.asp
1-2KV
9143
9143 appears to be a YYWW date code.
- Franc Zabkar
