Thomas P. Gootee
- Jan 1, 1970
- 0
Thanks very much for taking the time to read this.
I am looking for a way to implement a set of signal switches. The
design that I am modifying is a curve tracer that has three
connections to the device under test (DUT). I want to add the
capability to switch alternately between two devices under test.
The AC signals (sawtooth ramps, staircases, et al) that connect to the
DUT can range (according to user-selected switch settings) from just
above 0V p-p up to +/-15V, from about 0 Amps to 1.5 Amps, at
frequencies from 60 Hz to 22 kHz.
The user-selectable current-limiting resistance for the sweep-signal
path can be as low as 10 Ohms. So the switches' "on" resistances
should be "much smaller than" 10 Ohms.
Power supplies available are: two symmetric + and - 17.5V DC (could be
easily adjusted upward) and one fixed +5V DC. (Others "could" be
added.)
The switching rate(s): A "slow rate" would alternate between the two
DUTs on the order of once a second. But, if it's possible, it might be
desirable to also be able to user-select a "fast" switching rate, so
the devices' x-y displays would appear to be on the scope's screen
simultaneously. (And the user will also be able to select either DUT
by itself, i.e. without any automatic switching between them.)
So I'm wondering what the "best" implementation would be, for the
switches. I've looked at mechanical relays (e.g. reed type), "analog
switch" and multiplexer ICs, "solid state relays", and discrete MOSFET
or FET "transmission gate"-type analog AC switching circuits. Am I
just missing something else that's obvious? (I'm probably not familiar
with all of the device types that are out there.)
Relays would be cheap and easy. But I'm worried about their lifespan.
And the fast-rate switching option might be impossible, or at least "a
bad idea", with relays.
Analog switch types of ICs *sounded* good. But I haven't seen any
that have a low-enough "ON" resistance. Since the signal path's
resistance is user-selectable down to 10 Ohms, I'm thinking that the
switches' "ON" resistance should be no more than about 0.1 Ohms, with
less being better (and way less being desirable). And the analog
switch ICs that I've seen couldn't even begin to handle the currents
involved, anyway.
Solid sate relays look pretty good. But they seem pretty pricey
compared to just doing the same thing with discrete MOSFETs (or
FETs?).
So, I've been leaning toward trying to design some "transmission gate"
or bidirectional types of MOSFET or FET switches. I wasn't familiar
with them, and am actually not extremely familiar with MOSFET or FET
circuit design or analysis, although I've been learning a little more,
lately. ("Disclaimer": My BSEE degree is old (1978). And it had an
emphasis on automatic control instead of circuits. And I did nothing
but software from 1984 until 1998, when I started dabbling in circuits
again.)
Trying to get up to speed: I've seen various topologies for FET-type
switches, and am still slightly confused, maybe because many of them
seem to be for switching DC power instead of AC signals, and many were
for on-chip CMOS designs.
Would two same-channel devices that are basically back-to-back in
series work as a bidirectional analog AC signal switch, as I think
I've seen claimed? Or would we really need to use one N-channel and
one P-channel in parallel? (or was it "anti-parallel"?) And, if it's
the latter, how well would the device characteristics need to match?
Would it just be a matter of finding similarly-rated N and P devices
that had nearly equal RDSon values, and probably similar input
capacitances? (Not that I've actually FOUND any pairs like that,
yet...) And is it too much to hope for, that there might be available
some dual devices, with already-matched P an N channel devices in one
package? Or can anyone suggest some suitable N and P pairs that are
actually available (probably will buy from somewhere like
www.mouser.com)?
On the other hand, maybe I'm making this much more complicated than it
actually is. If there's a ready-made device that would be suitable, or
a standard way of doing this type of switching (it seems like there
must be), I'm all ears.
Thanks again, for reading this, and for any advice or ideas that you
can share.
Regards,
Tom Gootee
[email protected]
http://www.fullnet.com/u/tomg
added.)
involved, anyway.
FETs?).
again.)
www.mouser.com)?
can share.
Regards,
Tom Gootee
[email protected]
