Why PMOS input transistors are usually have lower flicker noise in OPAMP input pair?
Boki
Hi, All:
input pair?
Thanks!
Boki.
Mike
Hi, All:
input pair?
Flicker noise is still not well understood. It is generally believed that
PMOS devices exhibit lower noise because, given n+ poly gates on N and P
devices, the NMOS channel is at the surface of the Si-SiO2 layer, while the
PMOS channel is somewhat below the surface. Since many of the trap points
that lead to flicker noise are at the surface, a buried channel device
should have lower flicker noise.
Recent work [1] has shown that even PMOS devices with surface channels
exhibit lower flicker noise. If this turns out to be true, everything I
said before might not be completely true.
Until confirmation (and a new theory) is available, you probably won't get
in trouble by assuming that a) flicker noise is proportional to the number
of traps in the channel, b) P channel devices have a buried channel that is
physically separated from the Si-SiO2 interface, and c) the number of traps
in the PMOS channel is lower than the number of traps in the NMOS channel.
Here's a question for you to research, Boki: traps produce a Lorentzian
power spectrum (a single pole low pass filter), which is flat at low
frequencies and rolls off at 20dB/decade. Flicker noise has no flat region
and rolls off at 10dB/decade. Why doesn't flicker noise have the same power
spectral density as the traps that create it?
[1] Kenneth K.O., et al., ´1/f Noise of NMOS and PMOS Transistors and
their Implications to Design of Voltage Controlled Oscillators,¡ IEEE
RFIC Symposium, pp. 59-62, 2002.
-- Mike --
