Robert Hill
- Mar 5, 2015
- 112
- Joined
- Mar 5, 2015
- Messages
- 112
Hi there.
This is the first circuit I've designed.
I'm aiming to make a circuit whereby 2 people have a button and when asked a question the circuit indicates which of them pressed first thus indicating who gets to answer.
Here's the schematic: (I've omitted the means of resetting the 555 timers)
Here's how I hope/think it would work:
At the beggining the output pins are low which means the two LED's light as they are sunk into the 555 timers.
When one individual presses their button (represented by a switch here) two things will happen. Let's say switch 1 is pressed first. First the transistor (T2) attached to the trigger pin of the 555 will be grounded making its input go high and making the LED 1 turn off. Second the base of transistor 3 will have voltage applied. This will open up the collector emitter path of T3. This means that even if the second person then presses their button the current will be shorted to ground via T3. This is because the path to ground through T3 has less resistance than the path to T1 on the second 555 timers trigger pin. This means that the second person who pressed second cannot cause thier LED to turn off. Thus the person who's LED goes off is the person who pressed first.
So, will this circuit work? I'm sure there are more elegant ways to achieve this but i'm just learning so trying to work with what I know.
Thanks in advance.
Thanks in advance.
